Question about Samsung Televison & Video
Wont power up and makes a clicken noise - Samsung Televison & Video
  • mikewallace2 Mar 21, 2011
    Is it worth me fixing or buying new tv
    How do u go about doing that
    Genius:
  • Samsung Master
  • 1,039 Answers
Replaced capacitors on the power board that have domed tops.
Posted on Mar 21, 2011
    Sergeant:
    Champion:
  • 234 Answers
Power Board is dead or about to be.
  • renowiccan
    renowiccan Mar 21, 2011
    I would consult with a local service professional. Power boards can run between 100 to 400 dollars. Or you can go with solution number one and have someone mess around with the capacitors. But I would not recommend that because it may not be just the capacitors. So replacing the powerboard or the tv would be the best option. Be sure to Recycle what they take out and or the whole tv if you get a new one.
My fisher plow works fine and than seloned starts clicken an burns up
If your burning up selonoids and clicking sounds like a bad ground shorting them out,or there is an enormious draw due to a faulty or old pump drive.
Feb 12, 2017 | Cars & Trucks
Window motors sounds
It sounds like the power locks are making the noise to me. First the power going to the window gets shut off when you shut off the key. Second the window will not make noise unless the cable for the window regulator is broke, then the window will go down and stay down or up and wont go much of anywhere. Try to hold the power lock button and listen for the same noise. Most of the time the one of the switches go bad and keep trying to lock the car. Its usually the one that wont lock or unlock.
Feb 02, 2014 | 2005 Chrysler PT Cruiser
Lg 50PG20 IS MAKING A CLICKING NOISE AND WONT COME ON
Hello
Check the power supply regulator board for the fault.
Mar 03, 2012 | LG 50PG20 50 in. Plasma HDTV
MY LG TV WONT COME ON IT JUST MAKES A CLICKING NOISE
Bad capacitors in the power supply. 2200 and 1000uf. They're marked at 16v, put in 25v.
Nov 14, 2011 | LG 42LC2D 42 in. LCD HDTV
Went to start my mt 03 after too days and it just making a clicken noise
Sounds like the battery is flat, try to jumper from another battery, if not get back to me.
Jul 05, 2011 | Yamaha MT-03 Motorcycles
My car pulls to the right and makes a clicken noise wen you turn it
most likely cause is deformed tyres ,but the clicking noise ?? please ask a local mechanic to have a look ,i suspect the drive couplings
May 11, 2010 | 1999 Chevrolet Malibu
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
Can you help?
i think shes changing gear too fast and crunching the syncro ,give it time to do its job ,whats the rush anyway .Lots of people crucify gearboxes because they will not allow time for the syncro to slow the then match the splines for the gear to pass over .Her surname isnt button or hamilton is it??
Oct 25, 2009 | 2007 Ford Focus (3 Door) Hatchback
Wont power on makes clicking noise
Replace any swolen capacitors in power board.
Apr 25, 2009 | Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Televison & Video Logo
48 people viewed this question
Jerry Greenberg
Jerry Greenberg
