Question about Orion HDLCD4212 42 in TV
Tv turns on but screen continuously flickers - Orion HDLCD4212 42 in TV
    Genius:
  • Orion Master
  • 1,039 Answers
Replace capacitors on the inverter boards that have domed tps. If you don't fix it they will soon go out and you will have to replace the inverter boards. They are the long boards on the sides.
Posted on Mar 21, 2011
LED television is flickering what is wrong?
Flickering can be adjusted. In rare cases, power board inside it might need replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 21, 2017 | LG Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Tv screen flickers then turns black. has sound but is very faint.
The power supply may be failing, leading to video instability.
Nov 01, 2017 | Polaroid Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
TV screen flickers off and on
If for example a Samsung it is in the power supply of the set--no brand or model number indicated here so that limits the scope of a possible answer.
May 27, 2012 | Televison & Video
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
My 14 month old, 32 inch Samsung flat screen tv ''flickers'' The cable went 'out' 3 or more times and when returning the TV started flickering. We have unplugged & plugged it back in several times, but...
Check if this occurs regardless what the source of the signal, whether it is DVD or cable or a playstation. You can also check if the Menu flickers as well. If the menu does not flicker along with the picture it could be a problem with the source, probably your with the cable box or the port where it goes to on your tv
Aug 05, 2009 | Televison & Video
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Jan 10, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Orion HDLCD4212 42 in TV Logo
78 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
