Question about Magnavox MDR513H/F7 Player
MDR515h/f7 Dead....Think it is fuse? How can I replace it? THANKS
My unit simply died one day and would not come up under any circumstances.
I simply unplugged and disconnected it and carried to another room to test it,
and it powered up with no problem. When I returned it to my system, it worked
as if there was never a problem.
Posted on Sep 14, 2012
  • Magnavox Master
  • 508 Answers
You can replace the fuse (if the unit is not under any warranty) by carefully opening the top cover - the fuse is a small glass tube in the power supply (near where the cord connects) check its rating and voltage (the replacement MUST match the original). You should be able to reach this easily without further disassembly of the unit.
If replacing this inexpensive part does not restore any power to your unit, then you have a faulty/defective power supply circuit - this should really be tackled in a fully equipped workshop with adequate facilities by a qualified technician; it is not meant for end-users to repair when it fails due to the potential dangers involved. Experience suggests in many cases a dead unit is not just a blown fuse, but a switchmode power supply failure.
Try replacing the fuse first - then consider submitting unit to a service centre for a quote, then you can decide afterwards if it's economical/worthwhile repairing.
Posted on Mar 21, 2011
My Magnavox 46'LED TV (46ME313V/F7) is completely dead and will not turn on. We had a nasty storm past night and it may have been zapped??
Yikes...could be. There may be internal fuses on the power supply board that could have saved you. Replace in kind.
Feb 25, 2016 | Magnavox Televison & Video
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
Need magnavox dvr MDR515H/F7 code for URC WR7 universal remote
Check these codes. To know more, check this link.
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Feb 02, 2013 | Televison & Video
It won't power on. It had a blown fuse.
Most likely you have a dead short on the front end of your power supply board. Unless you have electronics repair experience, this is not something I would do on my own.
Jan 31, 2013 | Philips 32pfl3504d/f7
Magnavox MDR515H will not finalize
clean the OPU unit ( objetive LENS ) WITH disk cleaner. and fix it.
otherwise read your instr. manual go to the section troubleshooting
or download your instr. manual www. retrevo.com
If the problem persist you must go to the repair shop TV for fix it.
God bless you
Sep 30, 2012 | Magnavox MDR515H HDDVD Recorder
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
Magnavox mdr515h/f7 will not display video or audio. Was working fine before today.
After reading all the above I took my cover off and found the little fuse. I removed it and it tested ok. I had called Magnavox and they told me there is no fuse or anything like that. I took one last look before throwing it in the trash and there on the circuit board is a little button marked reset. I pushed it and now it works again. So there is both a fuse and a reset button.
Feb 25, 2012 | Magnavox MDR515hf7 Player
Mdr515h dosent work
Sounds like you need to do a "Hard Reboot" . . . Unplug the power cord and let it sit overnight, then plug it back in and it should work for you.
Jan 11, 2012 | Magnavox MDR515H HDDVD Recorder
Error code F7 and controls will not work
I think it have  F7 error not just F...
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
May 02, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Dead control panel
No F7 or E7 in my tech sheet could it be a F1 F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad let me know thanks
Jan 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
See all Magnavox MDR513H/F7 Player Questions
Magnavox MDR513H/F7 Player Logo
1,107 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
