Question about RCA RT2250 System
When I turn on my RCA RT2250, all I get is a chk speaker message and it turns itself off. Check all the speakers and they are okay.
3 Suggested Answers
SOURCE: RCA RT2250 Chck Speaker message
I have the same problem... I read that it can be a capacitor issue, they are on backwards. I just dropped mine off with the repair guy today... Does anyone know of a fix? Mine first had an electrical zap, then smoked, now CHCK SPEAKERS then off, and on standby...
Posted on Oct 24, 2006
does this mean system is fucked
Posted on Jan 12, 2010
What does it mean when u push the power button and the words ''chk spkr'' flashes on the display and still wont turn on??
The system connects to speakers with a certain impedance, i.e., 8 ohms, 4 ohms, etc. If you have connected the RCA speakers there may be a bad connection or the speaker(s) may be defective
Dec 08, 2012 | RCA RT2250 System
It says chk spkr when i try to turn it on how do i get it to work agaiun?
You probably have a blown channel. but check for a shorted speaker wire or bad speaker. Remove all speaker wires from the rear of the receiver if it still says check speakers when turned on, then one of the output channels is bad.
Feb 12, 2011 | RCA RT2500 System
RCA 5.1 Surround Sound Receiver Sounds fade in and out
chk how you are hooking up the speaker polarity minus to minus and plus to plus.
Oct 17, 2009 | RCA RT2250 System
When i unplug my rca rt2250 home theater system. the green light comes on on the right side. then goes off. everything works good after that speakers sound good. but once in a while that green light comes...
this is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Mar 12, 2009 | RCA RT2250 System
RCA rt2500 "CHK SPKR" comes on when i turn it on.
"CHK SPKR" Check Speakers. Remove all speaker wires and turn on receiver. If it still says check speakers, you have an amp that needs output transistors or possibly just soldering of an emitter resistor but thats rare.
Dec 28, 2008 | RCA RT2500 System
Chk spkr
That message means that you have a bad speaker or you have a bad amplifier IC most of the time. The amp circuit could have some other problem, but more times than not it is the amp IC.
How to check if it is the speakers or the amp circuit:
Unplug the speakers and turn it on. if you do not get the error message you have a bad speaker. If you do get the error message you have an internal amp problem. Then start plugging in speakers one at a time. If the unit turns on and stays on for a few minutes, turn it off and then plug in one more speaker. Keep doing this unit the unit gets the error message and when it gets that message you know that the last speaker you plugged in is the bad one.
Now the bad news
RCA no longer sells parts for their audio equipment. When the supply they have on hand right now is gone, thats it, no more RCA parts.
Now the good news.
The amp IC they use is a generic type that you may be able to get from another source.
But that is only good news if the amp IC is bad. It is the likely suspect, but without troubleshooting it on a test bench with the proper equipment, that can only be a good guess.
If you have found this help to you a good rating would be really appreciated.
Feb 17, 2008 | RCA RT2280 System
CHK SPEAKER MESSAGE UPON POWERED ON
I've got that problem too. Mine makes a clicking noise three times while displaying that message, then shuts off.
Sep 15, 2007 | RCA RT2250 System
Jul 22, 2006 | RCA RT2250 System
RCA RT2280/RT2250 RECEIVER
If you have speaker wires that have strands, you may be getting a short if one small strand is shorting across the terminals, or a poor connection. Check carefully, perhaps even by disconnecting and reconnecting the wires. Also check for proper polarity - positive to positive, negative to negative. (unlikely since it just started). You can also get a new set of wires and check speakers one at a time to see if it goes away. or get another speaker that works and then replace each one with that speaker in turn to see if it resolves it. Good luck
Mar 23, 2006 | RCA RT2500 System
RCA RT2250 System Logo
63 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
