Question about Pioneer Elite PRO-1140HD 50 in. Plasma HDTV
Turned TV on and every channel is a red background. Unplugged, waited and plugged back in...nothing!!! Help!!!
    Genius:
  • Pioneer Master
  • 1,039 Answers
If you are using the component input be sure all three wires green,blue and red are connected at both ends and are in the correct colored jacks. Component input is different than yellow jack which is composit video input. The 3 wirw component video in is progressive scan and all three wires must be connected correctly. Try this first if not replace the main board.
Posted on Mar 21, 2011
I have a 52"
Need model number and blink code at time of defect.
Feb 16, 2011 | Panasonic Televison & Video
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Polaroid flm-3232 locked or in sleep mode? Is that possible
Hi there!
I work in an electronics store and I've come across this problem before. The only solution that has ever worked for the people who call in or come to see us is pretty simple. You need to unplug your PC from the TV (if you haven't already done so), turn the TV on by using the "channel +" button. Some TV's when turned off at the wall will not turn back on again unless you press the channel + button. Give it a go and see what happens. Let me know if you need more help.
Also, it sounds like your laptop may not have been supported due to the wrong resolution being outputted through your VGA connection. When you get your TV turned on again I'll see if I can help you get them to work together,
Cheers and good luck!
Abby.
Oct 19, 2008 | Polaroid FLM-3232 Television
My picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
JVC AC32F702
22uf/250v from the 180v flyback output and 100 uf/50v in vertical and the last 220uf/16-25v from 16v line of flyback.
Apr 28, 2007 | JVC AV-32F702 32" TV
Sva-usa vr30
I've experienced the same problem with my VR-30 and what worked for me was I actually unplugged the power from the TV, waited about twenty seconds and then reconnected and when I turned it back on it worked fine. I've had my tv for about 2 1/2 years and I've had to do this probably a half dozen times so I've gotten used to it. Hope it works for you too.
Apr 02, 2007 | SVA-USA VR30 30 in. HD-Ready LCD...
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
63 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
