Question about Whirlpool GBD307PDS Electric Double Oven
Whirpool gold double oven model #gbd307pds09 ser #xr1502822 There is no led display at all. I can press the buttons and it beeps to make noise, but the oven will not heat up. Told by neighbor that previous owner self cleaned oven and that may have caused the problem. what can be done to fix this?
vest6
  • 196 Answers
SOURCE: Whirpool double oven shutdown during self cleaning operation and now is completely dead and the top oven door will not open.
Too bad someone didn't answer this sooner. Caused be poor air circulation in the unit. There is indeed a thermal fuse used in this unit. This problem has been around for a while and no real solution has been found. The closest "fix" is to remove the fuse, turn it around and only hook it down with the screw that faces the panel. The other screw hole is then bent to a 45 degree upward slant. This give the fuse a little breathing room.
Posted on Jan 26, 2008
SOURCE: oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Posted on Dec 21, 2008
TheRepairGur
  • 27 Answers
SOURCE: Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Posted on Apr 09, 2009
Macmarkus
  • 2605 Answers
SOURCE: Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
Posted on Dec 07, 2009
espressonist
  • 1711 Answers
SOURCE: My whirlpool double oven accubake GBD307PDS09
We have here a video showing how you can check the temperature sensor
We also here the parts diagram of your model
Posted on Aug 20, 2011
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Have a Whirlpool Gold dbl. oven. Last Fri. night oven started beeping and display the E0F2 code. Turned off brk'r till next a.m., turned on only to have in a rolling sequence going from 350 upper oven...
Good Evening!
Do you have the full model number of your appliance? Do all of the buttons beep when pressed? If not, unfortunately, the touchpad on your unit may have failed again. An E0-F2 is a stuck key error. The only way to fix this issue would be to replace your touchpad. Your more than welcome to send in your touchpad and control board for evaluation and testing. Contact us for more information info@fixyourboard.com. We also have replacement touchpads for your oven if the original OEM part is discontinued.
Ledgestone Technologies Keypad and Ribbon Cable Installation
May 25, 2017 | Whirlpool GBD277PD Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
We have a whirlpool gold double over, gas. We had a power outage and now the display panel is black. It will be beep if I press buttons and hold them but it won't turn on or cook. Is there an easy fix...
If you have a model similar to the one discussed in the link below then you probably have a control board failure. The control can be repaired for much less than the cost of a new one (which may well not be available anyway).
http://www.fixyourboard.com/techzone/ovens/e6_f2/e6_f2.html
Feb 04, 2011 | Whirlpool Ovens
Whirlpool Gold double oven - started beeping then all lights on the control panel went out. Reset the circuit breaker which makes the oven beep but still have no lights. Oven will not operate.
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one.2605a73.jpg That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2010 | Whirlpool GBD307PDS Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
RepairClinic.com
asplogo.jpg?ver=23
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Whirlpool GBD307PDS Electric Double Oven Logo
209 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
