you will need to install a convergence repair kit for your model. You can get the repair kit called the " WT46807, WS55807, WS65857,WS65907, WS73907 WT46809, WS55809, WS55819, WS65809
and WS65819 Convergence repair kit " which has the parts and the CD with instrucions. Its available at the following link http://tvrepairworld.com/mitsubishi_repair_kits
Please Note: The original remote (VS5043) is no longer available. The remote below is the recommended substitute remote. Substitute
remotes provide similar functionality to the original, although there
may be minor differences.
VS5043 Original Remote Control
VS5043 Substitute Remote Control
link to buy
about speakers can you tell me that are you able to hear sound from speaker or not.or is it the remote that showing no speaker..if it is showed by only remote then no need to change speaker ,but if speaker are not working at all then you need to change speakers........ check through t.v volume button that sound comes or not.
1) Will be a good idea to contact customer service, for guide you. Because the USB cables can be faulty. You must know something about the electronic for test this special wires.
If the green light which is power comes on and does not go off you do not have shutdown---what happens via menu? (see on screen display?) there are possible reasons but if possible try the self check this set has--and do a visual look inside for any signs of Glycol.
You will need to install a convergence repair kit. You can get the repair kit for your model at www.tvrepairworld.com the kits contain the parts and the CD with instructiuons.
This can be caused by blown fuse(s) on the middle PC board. The fuses are not the kind that fit in a fuseholder. They are soldered on the PC board toward the front. I would guess the repair would be a few hundred bucks, but changing fuses is normally the effect of another problem, NOT the cause of the problem, so there may be other problem to fix and add to your bill.
