Brother printer MFC790CW is showing error code 36 and stating unable to print. Paper was stuck earlier.
BubbaGuru
  • 70 Answers
SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
Posted on Mar 23, 2009
Mix-it-up
  • 832 Answers
SOURCE: Brother mfc845cw
See picture how to do that :-)
Posted on Oct 02, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Posted on Mar 29, 2008
SOURCE: error message on my printer that says unable to print 36
If this is a Brother clean the clear strip on the carriage assy. it is a timing strip for the carriage , I have seen ink on these cause the "36" code
Posted on Aug 05, 2009
  • 73 Answers
SOURCE: Brother Printer is reading ''unable to print 70''
YOu would need to remove jammed paper opening back cover.
Posted on Sep 23, 2009
Why brother unable to print 36 ?
head movement error, check for paper stuck , encorder strip dirty or maintenance unit faulty
Jul 21, 2014 | Brother MFC J220 Multifunction Printer
HOW CAN I CLEAR ERROR CODE 70 .Brother DCP -195C
Brother Printer is one of the best printing machine and comes with bundles of excellent features. Brother Printing machine is known for its high quality printing feature and its customer value. But sometimes user encounter various kind of problem while working with printing machine like Driver installtion and upgrade issue, Printer Set up/Configure issue, Paper Jam issue, Spooler error, Machine unable to print , Error code and so on. And being as a novice user you don't know how to fix them all issue then its recommended to get in touch with Brother Printer Support Experts for on the time assistance.
Here in this post we have mentioned about Brother unable to print 70 error message and how to fix it.
Require Sequential Steps to Fix Brother Printer Error Code 70
1. First you need to turn off the machine for few minutes then turn it ON again. If problem not gone due to turn ON/OFF process then you have to open the back cover.
2. Now carefully pull the green tab at the left and the right sides then fold down the fuser.
3. Always remember one thing there is no paper stuck inside the roller.
Note: If user doesn't find any kind of paper inside the roller then close the cover carefully. But if paper stuck inside the roller then gently remove it or close the cover.
4. Finally Turn ON the printing Device, if it shows ready it means unable to print 70 error has been fixed.
Above listed steps definitely resolve your printer error. If stil you are troubling with same error then its recommended to get in touch with Brother printer support experts at yahooemailsupport or pick a phone and make a call on toll-free Brother Printer Support Number 1-833-327-1999.
Brother Printer Customer Support Toll Free Number USA
Mar 29, 2013 | Brother DCP-195C A4 Colour Inkjet...
Brother MFC790cw shows on LCD "unable to change
Here's the online (english) version of your Brother "Multi-Function Center" Users Manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_790CW_990CW_EN_1600.PDF
The closest thing to your error message I can find is
"Unable to Clean XX" on page 156, in which case, your All-in-1 has either a (1) mechanical problem, or (2) a staple/paper clip or torn bit of paper is stuck in the machine.
Use a flashlight to look really closely for little foreign matter that
might be jamming your device - office staples can be insidious.
Mar 14, 2011 | Brother MFC790cw All-In-One InkJet Printer
The screen shows "Unable to
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the printhead is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Nov 02, 2010 | Brother MFC 210C All-In-One InkJet Printer
My printer Brother DCP 145C doesn't want to print. It takes the paper and then stops. It displays message: Print Unable 36.
Check for a paper jam. I just encountered this same error on my Brother MFC-290C, and that was the cause. I had to unplug the printer's power cable to clear the error message.
Sep 07, 2010 | Office Equipment & Supplies
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Brother MFC-6490CW printer error unable to print 36
Any of the 30 series errors say that the carriage is not free to move from side to side across the paper. You need to look close on each side of the machine where the carriage travels to see if there's a paper scrap stopping it. Also the encoder strip could be out of the slot in the carriage assembly. If all is OK you need a shop repair to determine if the logic or carriage pcb's are OK.
Feb 09, 2010 | Brother MFC 6490CW InkJet Printer
Printer message "unable to print 36"
That error usually means a paper scrap or something is stopping the carriage from moving across the paper correctly, or there are scraps caught on either side of the carriage assembly.
Aug 28, 2009 | Brother MFC-465CN InkJet Printer
Wont work at all just says unable to print 36
"Machine Error 36" and "Unable to Print" are error messages indicating something physically making it impossible for the machine to work. Hopefully, you could find a stuck paper or parts of stuck paper by opening the different covers (front, back, paper trays etc), the problem should then be solved by removing the paper and rebooting your machine.
However, if this does not work or you're unable to find the stuck paper, you will need to have service on this unit, to open up the machine.
May 17, 2009 | Brother MFC 6490CW InkJet Printer
228 people viewed this question
k24674
jasbo
jasbo
