Question about McCulloch 14" Electric Chain Saw Mcc1514
I have a Mcculloch electric chain saw model 235 for which is not pumping oil onto the chain. Can you please advise where I can purchase a new oil pump Regards Darryl.
  • smithassoc Mar 21, 2011
    I have stripped it down before.I am a A grade Electrician
  • McCulloch Master
  • 2,239 Answers
This is a full strip, and split side covers to get to the pump, this may well be a job for the local repair agent, having been apart it should then be PAT tested to ensure the double insulation it still good.
Posted on Mar 21, 2011
    I have stripped it down before.I am a A Grade Electrician
  • Andrew White Mar 21, 2011
    Sorry did not infer you were not capable, the pump is part no. 538005357, available through Flymo in the UK, if you are out side the UK i would check out the part no. on the web, i am sure you will find one mail order.
MCC1514 oil
Most any chainsaw , chain oil . Just so it is not dirty and will not clog the oiler.
May 17, 2014 | McCulloch 14" Electric Chain Saw Mcc1514
Husqvarna 235 - not oiling- pulled oiler out checked oil flow from tank all OK. Assembled oil pump with inlet line full of oil and ran pump with coreless drill in both directions and no oil flow checked...
You cannot just rotate the pump shaft and expect it to pump, it has to have a throw, this is done by an acentric groove in the nylon pump gear working on a steel pin in the pump cover, the bigger the throw the more oil is pumped, the biggest problem with the early model was the oil went down the side of the bar and not onto the chain, there was a later delivery/pick up pipe to solve this.
Jul 05, 2011 | Husqvarna Garden
No oil to chain
Remove the bar and chain. Run the saw for a few moments--it should ooze out oil from a side port where the bar fits to. If ok, clean the drive end of the bar oil passages, particularly the two small channels that run from the large holes out to the chain groove on each side. Clean the entire chain groove. If no oil came out of the port, the oil pump, connecting lines, and tank filter require attention. When everything is back together, run the saw for a few moments with the tip near some cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps.
Jun 06, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What oil does it take
You provide no model number so my answer is limited. Use "Bar and Chain" oil available at most home centers and hardware stores.
You can likely find an OM for your saw here: If the entire model does not work try just the numbers then choose from the list provided.
McCulloch International
http://www.mcculloch.biz/int/
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 15, 2010 | McCulloch 14" Electric Chain Saw Mcc1514
I just got a 14 inch McCulloch electric chain saw and it did not have a manual, I do not know what type of oil it takes.
Lou
May 15, 2010 | McCulloch Garden
Where do i purchase chain saw oil for electric chain saw
Hi
It would be helpful to know where durban is. In most parts of America "Bar Oil" is available at many hardware stores, and certainly at any chain saw dealership.
Oddly enough, many "Green" aware saw operators are now using vegetable oil as a lubricant. So Canola oil, Corn oil, or any other fairly thick, heavy vegetable oil will work fine.
The oil is pumped onto the bar at the top of where it exits the motor housing, and then circulates around the bar. Much of it is lost on the first pass the chain makes through the wood. This is carried away in the chip stream coming out of the cut. On many gas saws, you can see oil being slung off the chain when you rev the motor up.
The green feeling is, all this oil is left where we cut. Are we leaving a biodegradable oil behind? Or a contaminant that will take years to degrade.
See also:
http://www.fs.fed.us/eng/pubs/html/98511316/98511316.html
Stay safe, keep the blade sharp - use the protective gear as directed.
HF
Feb 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Need chain oil resevoir for Remington electric
I suspect you did an on line search, we can do no better. Remington has ceased production. Parts availability is limited to what is on hand. It might be advisable to save the money you would expend for parts and put it toward the purchase of a new electric saw.
Poulan has been in business a very long time and offers 8 different models. Some can be found at Lowes. HTH
Lou
Sooner or later you will encounter a part that isn't available for your Remington. Yours may be worth more as parts than as a complete assembly. eBay?
Oct 11, 2009 | Remington Electric Chain Saw
How can I get a manual for a McCulloch 235 chain saw?
Call 1-800-521-8559 and ask for parts, then ask for a PDF user manual to be emailed to you.
Nov 03, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 14" Electric Chain Saw Mcc1514 Logo
254 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
