Question about Epson Office Equipment & Supplies
Printer is saying printer parts at end of service line
  • 6,487 Answers
Once reset the printer will be able to work again but you should also check and clean the waste ink pads located at printer bottom. In order to do this you have to disassemble your printer.
Hope that helps...........
Posted on Aug 02, 2008
    Master:
  • 382 Answers
This warning appears because,The ink pads on the right rear of the printer are assumed to be soaked by now by the internal counters. Resetting the counters can be done with the free software from
http://www.ssclg.com
(or)
http://inkjetprinterhelp.us/epsonSSC.htm...
The pads are easy to clean but messy. Wear disposable gloves and old clothes. They can be rinsed out with water (lots of water), dried and replaced fairly easily
Please post back on how things turned or for further assistance!!!.. Thank you...
Regards!!...
  • 319 Answers
You need to replace the ink!
My printer is epson tx650.the problomis that it say 'the printer's ink pad is at the end of their service life'. please assist me with the solution.says RAKITA
Sadly the other solution is the usual corporate party line regarding "Parts at the end of their service life" and is intended to encourage printer owners to purchase new printers.
The reality is quite different.. Epson printer are generally capable of upwards of 3 to 10 years or service with minimal care unless the printer is being hammered 24/7 with almost constant printing, which is very unlikely.
Waste pads however are an achilles heel that do need some form of action to either replace or work-around to resolve.
The options available are either:
1. Go to a service centre where it is indeed prohibitively expensive to have the printer disassembled to replace the pads and have the waste counter reset.
OR..
2. Get an external waste ink kit to redirect any waste ink to an external tank (it doesn't remove the current pad contents) and obtain the relevant tool (either a compatible AdjProg service program) or WICReset tool with a key (one needed per reset) so you can reset the printers internal waste ink counter.
The cost of the latter option is around 20-25(GPB) total (including shipping) so compared to the tooth sucking Epson Customer "Care" option it's not exactly rocket science as to which is more cost effective.
Please ignore the rubbish about other parts being near the end of their service life... About the only other thing to note is that the printer gears might need a little grease but beyond that and flimsy plastic paper guides the printer can easily last 5 years with a little care.
Mar 05, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
My Epson Stylus photo R320 gave me an error saying "Service required. Printer parts are at end of service life. See printer manual for details". Which parts need replaced? thanks, Holly
It's probably going to be less expensive to REPLACE the whole printer, rather than paying a qualified printer technician $50 to $75 to disassemble the printer, change the parts (which won't be included in that charge for "labour"), to reassemble, and to test it.
Oct 11, 2010 | Epson Stylus Photo R320 InkJet Printer
Epson stylus cx5500 printer problem
probably refers to empty cartridges
everything has a service life and it could be a possible part that is wearing out and needs replacing
you have 2 options --ignore it untl it stops performing
or get in a service technician
Oct 28, 2017 | Epson Stylus 2200 InkJet Photo Printer
Says parts need replacing but they dont how do I get the printer to work
If the error message reads parts inside the printer are at the end of its service life, and both red lights flashing alternately while power light is off, it is an indication that the waste ink pad is full and needs to be replaced. This part is not user replaceable so you need to take in the printer for service.
Apr 11, 2010 | Epson C64 InkJet Printer
Is saying parts have come to the end of their life service needed
Your waste ink tray is likely full. The machine has a small container with a felt-like pad in it to absorb ink that is expelled during cleaning cycles. It is telling you that it is full so that ink does not spill out and make a mess where the printer sits. You should either have it serviced or purchase a new printer. Purchasing a new printer is likely less expensive, but beware of which one you buy. We have had customers bring new Epson cartridges (Epson 97 series) to us and tell us that they only got 25 pages of printing out of the black.
Jan 19, 2010 | Epson STYLUS R230 InkJet Photo Printer
Message says that certain parts have reached the
This is a mechanical problem or a hardware issue. You will need to bring the printer into repair to service and fix the printer. Some parts need to be calibrated and replace so that you will need to service the unit.
Hope this helps
Dec 02, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson C46 green and red lights flashing, saying parts need servic
Care to read this link
http://tricks-collections.com/2008/06/reset-epson-stylus-color-printers/
Goodluck
By the way emptying the waste bin needs disassembling of the unit then washing the ink foam.
Jul 19, 2009 | Epson Stylus C46 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Printer stating (parts inside your printer are coming to the end of their service life) it does not say which parts and it will not let me do anything now!
your waste pads inside need replacing, they are full of ink. the printer also needs to be reset.
i am not sure of your model, but costs usually
are $75 and up with parts and labor.
you will need to take it to a service center.
Jun 26, 2009 | Epson Office Equipment & Supplies
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
