Question about RCA Televison & Video
How do i get the code for my rca colortrack tv?
    Top Expert:
  • RCA Master
  • 75,417 Answers
Hello
Three digit universal remote codes for RCA are:
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit universal remote codes for RCA are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Mar 20, 2011
How do I replace the fuse on a colortrack 2000, RCA
open the back , follow the power cord and you will see the fuse around where the cable enter in , remove the fuse and replace by an other of same ratings. If you don't know anything about electronics don't do that because of some capacitors holds power even if the set is unplugged .
Do that at your own risk
Aug 05, 2010 | RCA Televison & Video
QUIERO SABER CUAL ES EL CODIGO PARA UNA TELEVISION SHARP SP
aver si te ayuda esto
Code 000 for RCA TV Code 003 for RCA TV Code 004 for RCA TV Code 005 for RCA TV Code 006 for RCA TV Code 007 for RCA TV Code 019 for RCA TV Code 054 for RCA TV Code 055 for RCA TV Code 082 for RCA TV Code 096 for RCA TV Code 098 for RCA TV Code 099 for RCA TV Code 100 for RCA TV Code 101 for RCA TV Code 102 for RCA TV Code 103 for RCA TV Code 129 for RCA TV Code 179 for RCA TV Code 181 for RCA TV Code 188 for RCA TV Code 190 for RCA TV Code 196 for RCA TV Code 202 for RCA TV Code 203 for RCA TV Code 212 for RCA TV Code 215 for RCA TV Code 233 for RCA TV Code 281 for RCA TV Code 352 for RCA TV
estos son los codigos
May 05, 2010 | RCA RCU600M Remote Control
I have a Brookstone large button remote, with no instruction manual. Tring to set it to a RCA colortrack 26" TV. Is there anything i can do?
Hi
Try this:
Automatic Programming
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
5. When the device turns on, press ok to store the code.
Good luck pls rate
Dec 18, 2009 | Televison & Video
I need help finding my code for my TV. Its an RCA Colortrack
To control an RCA TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0047, 1047, 1147, 1247, 1347, 1447, 1547
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 31, 2009 | One For All URC-3021 Remote Control
RCA ColorTrack 2000 - Picture getting small at bottom. Black line
Its the capacitors going bad. I believe you will see them as a pair.
Feb 24, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Lost remote were to get code for 1988 colortrack
cant get input to work to play dvd menu wont come up with universal remote
Dec 23, 2008 | RCA 27V520T 27" TV
No sound
If you are using a cable box try patching the audio from the box to your stereo system. If that does not apply to you, then getting the set fixed or replacement is in order. A colortrack 2000 is like 20+ years old. They don't make them like that anymore., Too bad.
Mar 24, 2008 | Televison & Video
Rca colortrack 2000 26"
They were noted for a bad relay. I doubt if you'll find one.
Feb 18, 2008 | Televison & Video
Televison & Video Logo
156 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
