Question about Hitachi C10FCE2 10" Compound Miter Saw
Require to get part replacement numbers for HITACHI KOKI C10FC 10" compound saw parts required: plastic handle containing switch,plastic handle which locks radus swing Thanks Barry
    Novelist:
  • 157 Answers
Hello Barry.
Found a parts list that may be able to help you out - very detailed and specific.
http://www.hitachipowertools.ca/en/Products?cat=39&pid=333
If this helps, please rate a four-thumbs up. Thank You.
Posted on Mar 27, 2011
Testimonial: "Thankyou for your help Regards Barry"
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
How do i replace switch on Hitachi miter saw
Oh come on.
You know the answer.
You start taking out screws until you can see the switch and then you replace it with a new one from the parts supply store.
Then you put all the screws back in.
Oct 16, 2014 | Hitachi C10FCE2 10" Compound Miter Saw
I have the old model c10fsb mitre saw but need to replace the two parts of the handle & the trigger,where would i get them ?
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
Mar 14, 2011 | Hitachi C10FSB 10" Sliding Dual Compound...
Require drill bits, drill chuck, taper shank for DH40MR.
you can find the parts your looking for here. Or you can call the number on the page for local purchase.
http://www.hitachi-koki.com/sitemap/sitemap.html
Feb 25, 2011 | Garden
My husband lost the safety key for our Hitachi Table Saw Model Number C10FR. This saw is discontinued and the customer service department at Hitachi will not return phone calls or E mails. Can anyone...
I found Hitachi customer service to be quite helpful in replacing my safety switch for my C10RA2 table saw. My C10RA2 has a fixed metal stand, not the folding stand, and the part number for the red safety switch or key is 531-992R, while the switch itself is part number 314-459. If you have the folding stand the part number for the switch is 321-620 and the safety key is 321-621. Hitachi customer service in US: 1-800-706-7337. I am going to buy two or three! Almost lost a table saw over a cheap plastic part.
Dec 27, 2010 | Hitachi C10FR 10" Job-Site Table Saw 15...
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Am replacing table insert (part 311-046) on Hitachi model C10FC. Appears new part does not have slot for saw blade to pass thru. Do I just use saw to create a slot before using saw for projects, or is...
Most manufacturers do not cut a slot in the inserts for miter saws. Just use your saw as normal and cut the slot as you cut through a piece of wood. It is adviseable not to use a brand new blade. The plastic could gum up your blade and cause it to dull quicker.
Oct 26, 2009 | Saws
Saw runs continuously
The on off switch has a contact that has probably fused together from making and breaking causing an arc. You may try giving it a good 'wrap' with the back of a screw driver to free it, or replace the switch.
Jul 15, 2009 | Hitachi C10FCE2 10" Compound Miter Saw
Need a detailed schematic for handle of a hitachi C10FC mitre saw
I would go to Ereplacementparts.com and type in your exact model number (there are about 5 saws) and they you can download a schematic of your tool. Hope this helps.
Dec 30, 2008 | Hitachi C10FCE2 10" Compound Miter Saw
Hitachi C10FCE2 10" Compound Miter Saw Logo
175 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
