Question about E-Machines etower 633ids PC Desktop
Were can I get a free recovery disk for windows\system\VMM32.VXD and download it
    Master:
  • 525 Answers
It wont be free but it will be cheap. Call emachines and request an ew set of recovery discs.
Posted on Mar 21, 2011
Testimonial: "true and thanks I never thout of that this web sit dos work than you agine"
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
I get exception OE at 0028:FF045A63 in VxD called from 0028:C1C77C57 in VxD
It looks like your hardisk or memory problem.. probably there is bad sector.. try to do 'Check Disk' (usually it called 'scandisk') first.
Oct 09, 2011 | Microsoft Windows 98 for PC
I deleted windows\system\vmm32.VXD on my etower633id
You must either recover that file from a backup, copletely reinstall windows, or use the Windows Recovery disk that came with your computer to repair the partition.
Mar 20, 2011 | E-Machines etower 633ids PC Desktop
It doesnt want to start it says what im describeing.
From http://support.microsoft.com/kb/194679:
Cause:
This behavior can occur if the Windows\System folder is missing or renamed, or if the PATH line in the Autoexec.bat file is missing or does not include the Windows\System folder.
To resolve this behavior, use the appropriate method:
Method 1 loadTOCNode(2, 'resolution');
  1. At the command prompt, type: dir vmm32.vxd /s If the Vmm32.vxd file is not found, you must install Windows 95 or Windows 98 again. If the Vmm32.vxd file is found, note the folder in which it is located, and then continue with step 2.
  2. At the command prompt, type the following commands, pressing ENTER after each command cd windows
    ren folder system
    where folder is the folder you noted in step 1.
  3. Restart your computer.
Method 2 loadTOCNode(2, 'resolution'); Using a text editor (such as Notepad), edit the Autoexec.bat file and add or modify the PATH line so that it includes the Windows\System folder. For example, add the following line to your Autoexec.bat file: path=c:\windows\system
Hope this helps,
-LL
Mar 16, 2010 | Toshiba Satellite 2060CDS Notebook
Hi... my problem is my PC cannot find a VMM32.VXD
You can find instructions on how to get around this issue here. You will need to be able to boot to a command prompt from a Windows Startup disk. When using these instructions, be very careful about the commands you enter. You must make sure you don't mistype anything since it could cause more problems.
Jul 07, 2009 | Microsoft Windows 98 for PC
Missing or corrupt files
well you will need a windows 98 disk to fix the problem. so if you don't have one or can't get one your best bet would be to take it to a technician.
Mar 08, 2009 | Computers & Internet
Vmm32.vxd problem on windows millennuim edition its saying load windows loader dont knoe it please help have no disc omputer given to me thanks
just go to start button goto run type regedit and press ctrl F and then type vmm32.vxd and press find and if the file that type is showed delete the vmm32.vxd and press F3 to search again the if you find another file like that again just delete it and its finished restart your computer.
Nov 25, 2008 | Computers & Internet
The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Jul 23, 2008 | Computers & Internet
E-Machines etower 633ids PC Desktop Logo
98 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
