Question about Samsung HL-R6164W TV
High pitch noise flashing colors Model: HL-R6178W
  • Samsung Master
  • 8,617 Answers
Most likely cause is the color wheel needing replacement.
Posted on Mar 22, 2011
No color only black and white picture and high pitch noise
high pitch noise is most likely the color wheel; pt# for L3 chassis:BP96-00674A pt# for L6 chassis: BP96-01103A
This could also be part of your lack of color, otherwise may also need MAIN or VIDEO PCB
Nov 29, 2013 | Samsung HL-R4266W 42" HDTV-Ready...
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv keeps shutting off. Currently no soud or picture
The set has a color wheel which may be bad, it often makes a high pitched or fan like sound prior to failure--it can even be a grinding noise.
I would with set unplugged remove the lamp cartridge and look where it faces---the color wheel can be seen.
What you are looking for is wheel shattered or missing any of the colored segments? If wheel does not turn or runs too slow set will detect this and shut lamp off etc.
Aug 29, 2012 | Samsung HL-S4266W 42" HDTV
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
My samsung HL-S5086W has a high pitched buzz that is present when muted, and continues for 2 or 3 seconds after you power off. Any ideas? I heard if it continues after power is off, then it is a fan, not...
Samsung BP96-01579A Color Wheelno the fans will not produce a high pitched noise. they will ususally produce a dull noise because they dont spin anywhere near as fast as the color wheel. the color wheel will start up before you see video and stay on for few moments after power down. if the fans were faulty the tv would give you message on screen.
Dec 22, 2010 | Samsung HL-S5086W 50" HDTV
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
Dec 13, 2010 | Samsung HL-S5086W 50" HDTV
Loud noise and no picture ON DLP model HLR5668WX/XAA
If it is a high pitched whine or a grinding sound it is a bad color wheel.
Not real difficult to determine and replace.
Let me know if I can assist you.
SD TECH
May 26, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Nov 19, 2009 | Samsung HL-S5087W DLP TV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung HL-R6164W TV Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
