Question about Bell Sports Deluxe Child Carrier
Where can I find a bracket to attach the bell child carrier to a seat with no bolt, like an extension piece or universal mount
4 Suggested Answers
  • 3 Answers
SOURCE: Bicycle Child Seat install has a rubber piece hanging in back
The rubber piece is designed to lock the tung on the back of the seat to the rack. To get it in place you need to bend the tung down until you can insert the rubber piece over the tung and under the two fins so that when you release the tung the rubber is locked into place. You will likely need to bend the tung down quite a bit. The rubber piece has two circular ridges that should be between the two fins that it is pressed into. These ridges will prevent the rubber piece from sliding out.
So basically, bend the tung down and press the rubber piece into the slot that is created. It will start to become clear once you get this far. Just make sure those ridges on the rubber are on the inside of the fins.
Posted on Apr 13, 2009
goalie39
  • 469 Answers
SOURCE: Bell child seat (carrier)
p100645reg.jpg The top should anchor to the seat post bolt, the bottom two should clamp onto the rear triangle. you should have the seat, a spoke guard, two clamps, and seat post bolt mounting bracket. if you received all the pieces. Hope this is of some help. Ed
Posted on Apr 30, 2009
bikeservice
  • 34 Answers
SOURCE: need instructions to mount Bell Classic Child
Bell Sports does not have a manual for your Child Carrier posted online. You will have to contact them directly.
(800) 456-2355 or e-mail us at Answer_Desk@bellsports.com
I sugguest you have the child seat install by your local bike shop to insure the safety of your child.
Hope this helps!
Posted on Jul 22, 2009
1993 electra glide front faring removal
1993/1994 Outer Fairing and Windshield for FLHTC, and FLHTC ULTRA
Removal
First remove the headlight assembly and the bolts, nut and the washers attaching the outer fairing piece to the windshield and inner fairing piece. THEN loosen the four bolts attaching the light bracket and the outer fairing piece to the fork brackets. Remove the upper bolts but leave the lower ones in place. Cover the fender. THEN rest the lower light bracket onto the fender. THEN remove the fastener securing the headlamp trim ring and remove the trim ring. THEN remove five screws that secure then headlamp assembly to the outer fairing and remove the headlamp assembly. THEN reach through the headlamp opening and loosen four locknuts on the two studs on each side of the headlight area which attach the fairing to the metal brackets inside the fairing. THEN remove the fairing by pulling it straight ahead away from the brackets.
Installation
First loosely position the outer fairing in place over the inner faring with the four studs going into the two brackets. Then install the five windshield fasteners through the outer fairing, the windshield and the inner fairing. THEN tighten the four stud nuts to secure the fairing to the brackets, being sure to have the inner and the outer fairing properly aligned at their outside edges. THEN position the light bracket so that the slots fit around the upper fork bracket bolts and thenalign the lower fork bracket mounting holes and replace the two lowering fairing mounting bolts through the light bracket and the outer fairing and the inner fairing and screw them into the lower fork bracket. THEN make sure that the rubber seal around the inner fairing is properly seated and not pinched and tighten the four fairing attachment bolts to 12-13 foot pounds (16 -19 Nm). THEN tighten the windshield screws to 4 inch pounds (0.45 Nm) but no more than this amount starting in the middle and working outwards on both sides. THEN reinstall the headlight assembly.
Jun 03, 2014 | Harley Davidson FLHTCUI Electra Glide...
I cannot locate petrol filter on toyota corolla 160i gle 1997 model
Hello my friend,
the only petrol filter is fixed directly with the petrol pump under the back seat so if its need change you must change the petrol pump , or attach one directly near the engine...
Feb 22, 2013 | 1997 Toyota Corolla
I own a schwinn trailway. I just purchased the classic child carrier but it doesn't seem to work. Do I need an additional piece to attach to seat.
Take it to where you bought it, if it was a bike shop they can show you how to do it. You want to make sure it is done right because that is a live person you are putting in it and why risk their life. Just like a car seat-make sure it is installed the correct way and the child wears a helmet, along with yourself. Remember, if you fall and hit your head who is going to take care of your baby? Do not put a child over 40 lbs in a baby seat.
Sep 19, 2010 | Bell Sports Deluxe Child Carrier
I have the Schwinn 700C W hybrid merge bicycle that i am trying to attach the Bell Classic Child Carrier seat to. it says to remove the seatpost bolt clamp. where is that?
I have a feeling it is made for old style bikes, not these new fangled things. The seat post clamp is the bolt , nut or quick release that holds the seat in the tube and stops it from going up, down or spinning. In the case of the new bike, it could be way down low, where it won't do you any good. I would suggest a clamp of some sort up top to make the child's seat sit level. Depending on how the child's seat is fastened on, you will have to make something work. Like a pipe clamp, antennae clamp, muffler clamp, something like that to replace the seat clamp. But iof you seat clamp is level or up high, remove the nut and bolt and see what happens with the child's seat clamp. Hope this helps.
Aug 08, 2010 | Schwinn Cycling
Hi: My bike was stolen and I lost the mounting bar from my Bell Cocoon child seat. How can I obtain a second mounting bar? Thanks, AUGUSTO.
Reach Bell support by email at Answer_Desk@bellsports.com or call (800) 456-2355 to see if they have the parts available for order. If not you can pickup a Bell Cocoon on ebay or craigslist for around $30.
You can find more information on the Bell FAQ site.
Nov 30, 2009 | Bell Cocoon Child Carrier
Need instructions to mount Bell Classic Child Carrier
Hope this helps!
Jul 13, 2009 | Cycling
Need Replacement Parts
heres the telephone number of bell, problably they can ship you the replacement parts, good luck
bell sports inc.
1924 country road 300 north
rantoul il, 61866-2355
1-800-456-2355
May 20, 2009 | Bell Sports Deluxe Child Carrier
Apr 27, 2009 | Bell Sports Deluxe Child Carrier
No manual for Bell Cocoon child seat
Call the company at 1-800-456-2355 and they can possibly email you a manual.
Apr 15, 2009 | Bell Cocoon Child Carrier
Bell Sports Deluxe Child Carrier Logo
532 people viewed this question
Top Bell Sports Cycling Experts
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
