Question about Maytag MV1153BAW 1000 Watts Microwave Oven
The oven beeps every minute. This started after a power outage. I unplugged the oven. It still beeps every minute! How can this be? All other functions appear normal.
A small blinking light on the left upper corner of panel after a power outage and I can't do any command. The interior lights don't even come on when opening door. I already reset the breaker
Unplug the microwave oven for 10 minutes in a attempt to reset the microprocessor ic, press and hold the start button for the same time and release. Now plug everything back in hopes it will restart, if no change! the keypad control board will need to be replaced along with other unknown parts, due to the nature of damage far cheaper to replace.
May 09, 2012 | Microwave Ovens
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
I had power outage and now all the number on the timer and thermometar are a mess
The microprocessor has been scrambled due to power surge when it came back on. There is only possible thing you can try, unplug the oven for 30 minutes and plug it back in, this might reset the ic, if not you will need appliance repairman to assess the situation.
Feb 05, 2011 | Thermador MCES MCEB Convection Microwave...
Wont start monitor say press start look like a battery symbol
There is an battery inside to keep time and settings in case of a power outage.. Check your maual for the battery location.. Unplug the oven,, replace battery and plug it back in..
Have a great day !
Apr 09, 2010 | GE JVM1540SMSS Microwave Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Feb 28, 2007 | GE JVM1660 Microwave Oven
Maytag MV1153BAW 1000 Watts Microwave Oven Logo
67 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
