Question about Kenmore Washing Machines
Machine fills fine wash cycle,only half full rinse
  • 1 more comment
  • bgravas Mar 21, 2011
    Not sure if I am posting in the correct spot - Kenmore Model#110269126691
  • bgravas Mar 22, 2011
    The washer fills at the correct rate during both the wash cycle and rinse cycle using either temperature water. However, the problem is during the rinse cycle - the water runs in the machine at the same rate but it will only fill to the small load level. If I hit the reset button at that time...it will continue to fill to the appropriate large level amount.
    Guru:
  • 262 Answers
Link for all appliance model numbers.
Please post your entire model number.
After you have clicked on the link below....
Just to the right of the "search" tab click on "help me find my model number"
Just click on the model of your choice In either video or image presentation
Then please repost the information.
Click on the link http://www.repairclinic.com/Appliance-Parts
Thanks....
Keith
Posted on Mar 21, 2011
  • Keith Drake
    Keith Drake Mar 21, 2011
    I suspect the cold water valve is the problem. It really doesn't matter what the temperature switch is set to because most rinses are cold water.
    Set the temperature switch to warm and start a fill. While the washer is filling turn the spigot to the hot water valve off and see how the cold valve is filling.
    If the cold valve is filling slowly and the hot is okay you can even swap the hoses and see if the problem swaps.
    Replacing the inlet valve will most likely correct this problem. It can be obtained from the following link: Sears PartsDirect .
    The other question that is usually asked is how I access the water valve to change it. This information is in the image below and will be helpful to you if you change the valve yourself. Your particular washer has two end caps that must be removed to access the two screws holding the console down.
    I hope this information is helpful to resolve this problem.
  • Keith Drake
    Keith Drake Mar 22, 2011
    If you are sure the inlet valve is good....ensure the washer is not draining on the rinse cycle or siphoning the water out.
    Now Let's check the pressure switch and tube. Note the video link
    Click on the link http://www.youtube.com/watch?v=HZZ2bDMsp...
    Please post results
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
My whirlpool washer periodically gets stuck on rinse.. the water continues to run but its only about half full so it must be draining. My water bill was over $100 last month, please help.
check the lid switch, if it isn't working right the machine will not enter the spin cycle, also the timer may be going bad, it could stay stuck in between the rinse fill and rinse cycle
Jun 21, 2011 | Whirlpool Washing Machines
Our machine works fine, but the water just trckles in when it adds water for the rinse cycles. It can take 20 minutes to fill the tub.
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. Replace the water valve with this part.
Jan 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Kenmore 80 series washer will sometimes not fill in rinse cycle, sometimes half fill, sometimes 1/4. fills fine for start but not rinse????
HI, This will be the result of a failing control sector. The control sector can be a timer module, or a single printed circuit board. In any case, this will be your culprit. Have this damaged control replaced, asap. Once replaced, your unit will operate correctly.
Dec 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not fill in rinse cycle.
hi, When the washer acts up in the rinse cycle, will it try and fill and then the water starts going out the drain hose? If this is the case, the drain hose is either needs to be raised to be as high as the top of the washer or, it needs to have a loose fitting where it goes into the drain pipe so it can have air **** back into the drain hose after it releases the wash water.
i know this is a lot of info that might not even be the answer but, I am giving you the most common fix. Please let me know if I have answered your question or let me know if I can assist you further.
If this does not seem to be the answer, maybe I need clarification.
Vic
Jul 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
