Question about Maytag MSD2756G Side by Side Refrigerator
Can I recharge the refrigerant myself? or do I really need to call a pro?
  • Maytag Master
  • 5,568 Answers
You need a pro; unlike a car AC, there is no nipple provided for recharging the system, it must be cut open and soldered shut. Probably $100-150 US.
Posted on Mar 20, 2011
  • 2,418 Answers
You can if you have a manifold gage set and a vacuum pump. You will need to know the type of refrigerant, and be able to get it, (some refrigerators use 134a which you can get at a local auto parts store). Be sure you have fixed the leak. You will need a pinch port valve to access the system to run the vacuum and then recharge it through. If the refrigerator belongs to you and you wish to try and fix it you can. no special license needed.
How can the gas be refilled in the freezer unit
I can explain how to do it but you will need a F-Gas certified professional refrigeration technician to do this job.
If you unscrew the 4 screws to the compressor closet, you will see a copper stump on the side of the compressor, that stump used to have an access valve that allows refrigerant to be measured into the refrigeration system. For gas to be reapplied a technician will have to re-braze a valve onto that stump in order to recharge refrigerant into the system.
Jun 02, 2014 | Whirlpool 10 cu. ft. / 283 liter Chest...
Recharging my dometic rm 2611
closed system replace cooling unit
Jan 17, 2014 | Dometic RM2620 Refrigerator
What type of refrigerant is used in a Frigidaire side by side it is about two years old?
If you locate the serial tag for the unit, usually inside the cabinet on the inner wall - you will that information. It is different for each model and year produced.
Aug 01, 2012 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
My 2006 Ford F-150 super crew's A/C only blows hot air.
No there is not really a thermostat. The first thing you need to check is to see if the AC compressor on the engine is engaging, if not you likely have a refrigerant leak and need that repaired and the system evacuated and recharged. Always confirm the problem with i have laid out with a professional HVAC tech before starting any repairs.
Jul 03, 2012 | 2006 Ford F-150
Rm6252 refrigerator
cooland [freon] is not yellow it a gas tipe and most state you need a licent to buy it.
Feb 21, 2012 | Refrigerators
Leaks R-22 and has to be recharged every spring. Is there a way I can recharge this myself and save the service call?
pls try to find the leak first you check with a torch if the flame change the color this is it or with soap buble or with electonic detector. then after repair you proceed to charge you put the quantity mentionned on the name plate data of the a/c
Apr 28, 2009 | Heating & Cooling
Need to know normal pressure for 134-a to recharge my refrigerator
Depending upon the way you charge it you could introduce air into the system. The lines need to be bleed before charging to make sure the refrigerant is in the charge lines and not air. Most folks that do not do this for a living make that mistake.
With air in a 134 system problems will abound. The only way to really charge a system is to use a vacuum pump to pull it down then charge to the correct lever in ounces as provided on the label of the refrigerant u purchase
Apr 17, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Samsung RS2577BB Refrigerator/Freezer Will not Cool
Chances are you need to get the refrigerant recharged. This can only really be done by a professional due to the equipment needed. He will also find where the gas is leaking from.
Oct 11, 2007 | Refrigerators
Frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Sep 12, 2007 | Daewoo FR-147RV
Maytag MSD2756G Side by Side Refrigerator Logo
260 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
