Question about Jabsco 29200 0120 Marine Manual To Electric Marine Toilet Converstion Kit for Manual Toilets
Hi we have a an electric Jabsco 37245-1092on our cat. unfortunately it doesn't flush anymore properly. we can pump water in the bowl but it doesn't flush out. there is a strong swirl however but the water doesn't go out, neither to the see nor to the blackwater tank. before we detach the tubes where could the problem be? thanks for your help Daniel Grivel dgrivel@me.com
3 Suggested Answers
bonedivers
  • 1140 Answers
SOURCE: Have a Jabsco Self-Priming Macerator
could be either, locate pump and make sure it's not plugged (fun, fun)
Posted on May 20, 2011
rvanderbr802
Try removing the plastic cover, from the motor and turning the shaft that extends out the back of the motor. I used pliers and the macerator is working, now. My problem was that a pebble had jammed the impeller. Turning the shaft freed the pebble from the impeller.
Posted on Dec 16, 2013
JABSCO ELECTRIC TOILET HAS JUST SUDDENLY STOPPED WORKING ?
Contact your local Jabsco retailer or their technical site here: Jabsco How to Videos Jabsco Tech
May 22, 2017 | RVs
Jabsco model 37010-0090 electric head. sometimes no motor run or flush when button pressed. By turning slotted shaft on end of motor , button then activates motor and flushes.
Sounds like the motor commutator and brushes need some attention. Not a difficult job if you have been there before but it can be tricky for a novice.
Oct 14, 2013 | ITT Jabsco Manual Marine Toilet Compact...
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
Hi, please help i recently replaced all seals and gaskets in my jabsco compact marine toilet, it worked well for two weeks when all of a sudden it would no longer empty the bowl. It pumps water in easily...
Hi
I don't specifically know your model of marine toilet but with my Baby Blake I have known the joker valve turn itself inside out (I think due to someone forgetting to open one of the seacocks) which meant that very little would pass out through it.
Mar 22, 2011 | ITT Jabsco Manual Marine Toilet Compact...
Toilet backs up after use. even when holding tank is empty. we only use fresh water to flush from shower nozzle. toilet is fairly new replaced by original owner.
The system does not work, as you describe, you MUST use the unit's pump lever as the intake and removal are part of it's function. Use sea water to flush, the system is designed for that.
Jan 30, 2011 | ITT Jabsco Manual Marine Toilet Compact...
Water rising in bowl at sea
Hi!
This is caused by the head being mounted below the waterline. You will have to install a vented loop in the hose between the head and the seacock. (Easily done)
Here is a good website to explain what you're up against:
http://www.myboatsgear.com/featured_product/vented%20loops.asp
Hope this helps.
Jan 19, 2011 | ITT Jabsco Macerator Pump MotorPump...
The pump keeps running after flushing. Have to tap pump tank unit slightly to get it to shut off. Also from time of installation the water level in the bowl was and still is very low, any way to raise the...
hi keith
Bloues hear.
the water level in the boul is standerd to the manefactuer. the plumber cant help for that. if u put a level on ur toilet and iets level there is noting u can do about it.. the water that keeps on runing is ur seal rubber, its located at the bottem of ur flush meganusum. step 1.... tack off sistern aka pump. then step 2 ... unscrew your flush meganusem, will be the 1 in the middel of sistern. step 3 ... after unsrewing it u wil see there is a rubber. if the rubber looks fine then u must ajust ur flush meganisems arm or lubricate it. bt if rubber is misformed or teared ... u must go to a plumbing shop with the rubber. they will give u new 1 for cheap. and u can just reaplace it and esembel the sistern again
Jul 05, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Jabsco 29200 0120 Marine Manual To Electric Marine Toilet Converstion Kit for Manual Toilets Logo
52 people viewed this question
Top Jabsco Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Jabsco Boating Expert? Answer questions, earn points and help others
