Question about GE JVM1750DM Microwave Oven
Microwave runs constantly if plugged in, light is on and fan is running, unable to get it to turn off if plugged in??
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs with door open
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
SOURCE: Microwave Fan won't shut off, no display
Depending on which brand you have I would think that the Thermal switch on top of the magnetron or one of the door switches has probably given up the ghost. However, if the display does not come on you probably have a micro or Psu fault on the display panel. Not to be attempted if you are not familiar with microwaves or electronics. Please unplug before opening. Good Luck, JUS004
Posted on Jan 05, 2008
red-pt
SOURCE: Over the range microwave
I have the R-1460 in the same series with the identical symptoms. After reading MicrowaveSvc's solution I started taking apart to view the door switches and found the upper door switch to be the problem, but not a switch failure a support failure. A small bottom plastic support post that holds the switch in place was broken (probably from repeated use/abuse) allowing the switch to move when the door hooks were engaged, thus not actuating the button switch. Since the problem was mechanical rather than an electrical bad switch, I made a small support arm for the switch from an old plastic mechanical pencil and glued it in place to hold the switch in its correct position. Problem solved, microwave works! Thanks to MicrowaveSvc's description of door switches.
Posted on May 26, 2007
SOURCE: Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Posted on Apr 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: frigidaire microwave light turns on, fan does not, does not heat
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 28, 2008
Need to disconnect fan it constantly runs
The best bet is just for you to take the microwave to a microwave repairer for the repairer to see how he can fix the fan that runs constanly
Jan 22, 2011 | Whirlpool MH3184XP Microwave Oven
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
Jan 04, 2010 | Maytag Appliances Over-the-Range Microwave...
Fan runs constantly and can't be turned off. Unplugging it for months doesn't help
Fan relay is stuck on or button is bad (assuming this is over the fan stove function you're referring to) if not same still applies.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Jan 09, 2008 | Microwave Ovens
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Sounds like a defective door interlock switch or a broken switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it's not a problem with the door switch or door switch mount, it may be a problem on the control board. We repair these for $39.95 for customers nationwide. Reply back if you still ned help.
May 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1750DM Microwave Oven Logo
2,960 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
