Question about Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module
I'm having a tough time with my 96 jeep cherokee sport. It lagging when starting, sounding like its having a tough time turning over. I took out my alternator and got it checked and it was fine. I took out my starter and got it checked and it and was fine. Put a new battery in and it worked for a week and then I went to start it and no turn over or clicking when trying to start. Any suggestions what it could be??
    Top Expert:
  • Directed Ele... Master
  • 81,400 Answers
The 1st thing you do is have the engine control module checked for fault codes, any Autozone or other parts store will do this test for free. Also verify the fuel pressure is within specs.
Posted on Jul 21, 2017
2 Suggested Answers
  • 32 Answers
SOURCE: Jeep Cherokee will turn over but won't start
i would lean toward the crank position sensor or the camshaft position sensor, these two are part of your main ignition system without one you will have no sparky spark, if youve done anything around the transmission area also look for broken wires/ plugs terminated in the right receptacles( only if you had worked near or around the transmission though)
Posted on Oct 05, 2009
My 2000 jeep cherokee sport is getting fuel and spark and won't start what can it be
If Fuel and Spark are Correct, it must be Air. Are any codes set? If so what are they. Check MAP Sensor 96 Jeep Cherokee MAP Sensor
Apr 20, 2015 | Jeep 2000 Cherokee Sport
Have 96 jeep cherokee sport will not start not getting fuel or fire cranks over fine all fuses and relays are good
Hey I have a 96 grand Cherokee aswell I had the same prob. When you turn the key to the on position does the dash light say your out of gas but you know your not? If so it's your crank shaft position sensor a $60 part it's located above the tran so youll have to lower not drop it to get to it. Shouldn't take more than 30 mins to do hope I was able to help an good luck
Aug 20, 2011 | 1996 Jeep Cherokee Sport
I'm having problems with my 96 jeep Cherokee sport. When I try to start it it sounds like it has problems turning over a few times then it will fire up. I put a new battery in it, checked the alternator...
I would tend to agree its very possible you have a bad starter.You could remove it and have it tested.Most of your local auto parts stores do this for free.
Mar 16, 2011 | 1996 Jeep Cherokee Sport
1998 jeep Cherokee Sport wont start
Sounds like your battery is way down. have it checked/charged and load tested. then have the charging system tested after you get it started.
Sep 28, 2009 | 1998 Jeep Cherokee
1996 Jeep Cherokee Sport bogs down
I just posted a simular resonse in another post. What is sounds like it that the fuel pump is starting to go bad. When it heats up after use the pressure drops not pusing the full amount of fuel. Whenits cold it works fine until it heats back up 10-20 mins. remember fuel in the tank helps cool the pump so keep it soewhat full but sounds like the damage is done. your probally gonna have to replace it.
Joe
Mar 08, 2009 | 1996 Jeep Cherokee Sport
96 Jeep Cherokee Sport Hard Starting
The Engine coolant temp sensor would ABSOLUTELY cause a hard start, but don't guess get the codes check again at Auto_Zone to make sure. Another cause of that kind of hard start is a dirty throttle body/ intake manifold. Use INTAKE cleaner and a rag clean the intake esp[eciall in the throttle body area. Good Luck
Dec 28, 2008 | 1996 Jeep Grand Cherokee
My 1996 jeep cherokee sports is turning over but not starting. No voltage to input side of coil. ASD relay seems fine, crankshaft position sensor??
The CPS is one of the first places to start, but remember that the signal goes thru the ECM first, which ultimately supplies power to the coil, I've had to replace the ECM on my 96 Grand Cherokee 4.0 3 times. The dealer wanted to replace the crack and cam sensors, but it was only the computer that was bad.  Sorry I cant give you any definitive answers but I did get it to turn over when I hit the computer with a wrench!
Dec 08, 2008 | 1996 Jeep Grand Cherokee
96 jeep cherokee sport starting problems
Try the wiring harness that attches to your ignition switch. Check for burn marks. also if it is auto check ur inhibiter switch located at the bottom of shifter under console
May 26, 2008 | 1996 Jeep Cherokee
Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module Logo
43 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
