Question about Kenmore 24032\24036 Top Load Washer
Spin Cycle on Wash Machine does not work
Washes great though
Kenmore top load washer about 8 years old
  • isymv Aug 02, 2008
    Washes great, won't spin
  • 5,911 Answers
You probably have a defective lid switch. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. If you need assistance in determining a part number, please post back with your model number. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very simple and inexpensive repair. However, if you require additional assistance, please let me know. I hope this helps you.
Posted on Aug 07, 2008
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Spin cycle does not work. Machine only hums when it should spin.
Check the motor capacitors. Wash cycle and run cycle capacitors are different in some m/cs.If these are OK motor winding to be checked.
Now it is ten years old and you are likely to get ball bearing problem. Get an repair estimate and decide which suits your budget.
Apr 06, 2010 | GE WBSE3120B Top Load Washer
Kenmore model 110 23832100 stps after wash cycle before the rinse cyle. The old water has not drained.
If the machine fills, and washes and won't drain or spin out the water you need a direct drive coupling. It is located at the bottom and is on the motor shaft and consits of 3 pieces. Check this first, easy fix and not expensive.
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Aug 04, 2008 | Washing Machines
Kenmore wash machine will not spin
Eight years is getting kind of old. When the clutch or transmission goes out, it costs more to replace the part than to buy a new washing machine. You'd better plan a shopping trip rather than spring for that $100.
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Washer stops after wash cycle
the timer is bad you could try cleaning the points by taking it apart very hard to do though
Aug 27, 2007 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
