Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Refrigerator says Er Freezer says FF - Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
  • 42 Answers
That sound like a the board found an error in the freezer fan, try replacing the fan motor.
Posted on Mar 20, 2011
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
My freezer says ER and my refrigerator reads FF and will not change
ER = Error and FF= Freezer Fan. You have a fan issue.
Dec 29, 2017 | Refrigerators
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Er ff what's that?
FF(Freezer Fan) this is the fan that circulates cold air thru the freezer as well as the refrigerator. If this is the first time the er has appeared, you need to unplug the unit for about 10 minutes, plug the unit back in. This should reboot the unit and erase the er.
Jul 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error message ER FF - refrigerator is not cooling as a result
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
22 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
