Question about Sharp LC37D64U 37 in. LCD HDTV
Television power light is on, but can't do anything with the television. Have tried ALL of the potential fixes listed on the web with regards to holding the power button and have also called Sharp.
  • 42 Answers
Sounds like a blown capacitor on the main power board. look for the cylinder shaped capacitor on the board that the top looks bubbled up (rounded not flat). It's usually 2200uf capacitor. you will have to unsolder it and replace it or just replace the board. Capacitor $5 board moe like $200. try the cap first. they are available at radio shack. may be different in size. you will have to run extra wires to the new cap sometimes.
Posted on Mar 20, 2011
The screen on my Samsung DLP tv turned off with the volume still playing. The lamp light started flashing. We replaced the lamp and it doesn't seem to have fixed anything. What could be wrong?
Lamp Fan could be defective or the Ballast Board ,it is what powers Lamp.
Encompass Parts Distrubution 1-800-638-3328
Go to this website and type in your Model# for list of Parts /Prices
Oct 07, 2010 | Samsung HLP6163W 61" Rear Projection...
I have a curtis Mathis flat screan television and am trying to program my verizon fios remote control to operate the television as well as the fios box. I tried every code that is listed in the verizon...
Since I can't find anything about your set except the fact that it's an older set I suspect that the trouble lies in the fact that Fios won't control a set this old. I do believe this one has an analog tuner which is now obsolete.
Regards
Jun 19, 2010 | Curtis-Mathis CM32010 TV
My LG television when powered on the red light kept on blinking without showing anything on the television
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 17, 2010 | LG 32LC7D Television
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Tv will not power up. green light comes on for
I have the same problem, did you ever get yours fixed if so what was the problem
Aug 17, 2009 | Mitsubishi WS-65809 65" Rear Projection...
When i power the television on, the television
this set should have a built in self diagnostic feature; if you try to turn it on and it does not make it on---watch the power light and count the blinks---for example----3 blinks and a pause and 3 more blinks is the error code---you may have to unplug the set and start fresh--some sets only repeat the error codes 5 times.
Aug 06, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Rear projection tv flickers green/shuts off
rodman, i just started having the exact same thing on my Sony (same model). it's about 5 years old. did you ever find a solution?
Dec 10, 2006 | Sony KP-57WS500 57" Rear Projection...
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
See all Sharp LC37D64U 37 in. LCD HDTV Questions
Sharp LC37D64U 37 in. LCD HDTV Logo
67 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
