Question about Pyle Audio Players & Recorders
I have a pyle pro pta3000 power amplifier,when i hook it up, one channel works fine and the other channel works intermittenlly.
  • 1,591 Answers
You either have a cold solder joint or a bad capacitor or a bad input.
if it's only happening from one source, look to the source as the issue - there may be a DC voltage riding on the output into the amp, saturating the input until the caps charge...and if there's a bad cap on the input or output, it may take time for it to stabilize.
Meter the input at zero signal, and meter the output as well looking for DC voltage riding on it.
compare readings at zero signal between channels for discrepancies.
ground both inputs and start metering .
check the low ohm resistors between the output transistors unless it's a hybrid.
when I say transistors I mean mosfets.
Posted on Mar 20, 2011
PYLE PTA 3000 cut off and will not come on
Will it no longer come on anymore, or does it take multiple tries before it comes on? If it has stopped coming on all together, you may have blown a component on the unit.
Oct 20, 2013 | Pyle Pro Ppa300 3000 Watt 2 Channel Dj...
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
Could someone please help me with the 3-digit remote control code for my Pyle Pro P1001AT amplifier?
Since the code is generated by the REMOTE, it would help to know the BRAND of remote you plan to use. The code is not generated by your pyle amp
Mar 11, 2013 | PYLE Audio PYLE P1001AT 4-Channel 1000...
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
PLEASE HELP with PYLE PLUS GXA-280A
If the ground terminal is connected to a ground wire, the ground wire isn't connected to a good ground.
Sep 24, 2007 | Pyle PLA985R Car Audio Amplifier
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
437 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
