Question about JVC Kd-r810
How do I set preset radio stations? - JVC Kd-r810
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Posted on Aug 25, 2008
  • 733 Answers
SOURCE: how to set time and preset radio stations on
Here you go.
http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP4000UBOperationManual1019.pdf
Posted on Feb 08, 2010
  • 31 Answers
SOURCE: I set radio stations and
The yellow wire in the wiring harness of your head unit must be connected to a constant power source, a live terminal in the fuse block that is connected to the battery and not affected by the ignition switch. If you do not have your manual this may help: http://resources.jvc.com/Resources/00/00/95/GET0182-002A.pdf
Posted on Mar 22, 2011
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How to I delete an occupied preset and enter another channel
My experience has always been to replace the current station preset with the new.
I recall two process:
  1. The first locate the new station that you want and tune the radio to the station. Press and hold the specific preset for several seconds to replace the old station with the new.
  2. Tune the radio to the new station and press the set button if so equipped and than press the preset button. In some radios they have group 1 and group 2. In that case press the set button once for set 1 and press it twice for set 2 and then press the preset button.
Hope this has helped?
Jan 12, 2016 | Cars & Trucks
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
May 07, 2009 | Car Audio & Video
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Jan 08, 2009 | Bose Wave Radio
Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
Oct 09, 2008 | 2001 BMW Z3
Setting preset stations
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
Feb 22, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
JVC Kd-r810 Logo
62 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
