Question about Liebherr KIU 1444 Premium Compact Refrigerator
My Liebherr KIU 1620 Larder Fridge is too cold , almost freezing the food at temp setting 2. Is this likekly to be a failed thermostat ? We had one replaced in 2004 . Is it easy to replace ?
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
  • 400 Answers
SOURCE: Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Posted on Mar 05, 2009
mastatech
  • 478 Answers
SOURCE: Replacing fridge thermostat
Should be prtty easy the wires can go either way, and just follow the bulb to install in same position
Posted on Mar 14, 2009
  • 478 Answers
SOURCE: hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
Posted on Dec 10, 2009
  • 93 Answers
SOURCE: Ice build up inside refrigerator Liebherr K3150
may be you have a bad temperature sensor or bad control board.
Posted on Mar 01, 2010
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Liebherr KBES3650 Stainless Steel...
Fridge is not cold -temp sitting at 17 c
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Aug 23, 2010 | Liebherr KGK 2833 Comfort Bottom Freezer...
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
Sep 23, 2008 | Liebherr Refrigerators
Liebherr KIU 1444 Premium Compact Refrigerator Logo
240 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
