Question about Cyberhome CH-DVD 300 DVD Player
I have two CH-DVD 300s. They are a few years old. The one most often used started randomly not reading DVD discs...some would load and run fine...others would say "loading" forever...only to result in a "bad disc" message. I would try a different DVD player and the movie would play fine...I would try a differrent move in my CH-CVD 300 and it would play fine! Now that player won't turn on...it stays in standby mode and the other same model player is giving me the long term "loading" message resulting in the bad disc error! Frustrating!
  • 3 more comments
  • rk21944 Mar 22, 2011
    the second player (in permanent standby mode) was doing the same thing as the first player. I opened top and cleaned what I believe to be the optical lens. (small round glass "eye" that appears to be on a "slider" that would slide it under the disc uring operation.) I after done, the results were the same. would there be any settings that could need to be changed for certain movies to be able to be read?
    I left the top off and watched it operate. The optical lens did not slide in or out at all, though it appears to me that it is supposed to. What normally initiates movement of the lens?
    Interesting. If the eye does not move (reset) upon insertion of disc then it sounds like that would be a problem also..And this one doesn't move. It remains in one position. i can see the red light through the disc. If the optical lens isn't positioned properly, it wouldn't be able to focus to read the disc, right?
    I can slide it manually, but it doesn't slide during operation. So does that mean the problem is the sled motor? Or, is there a need for any lubrication of the "rod" that the slider is on?
    Unfortunately, though the problems(s) may have been identified - I was not able to fix my machine. But thank you for your prompt insightful responses.
  • 10,594 Answers
Please clean optical lens of player-1 that gives bad-disc error randomly, please use dry q-tip/ cotton bud to clean optical lens and need to take off top cover to access the lens, if you are handy with electronics stuff repair then should attempt that.
Player-2 remains in standby mode due to either power supply board or signal processor chip problem so I would suggest to transfer/ install its dvd mechanism in working dvd player-1 if lens cleaning does not fix the problem and you will get a working dvd player.
Hope this will help.
Thanks.
Posted on Mar 21, 2011
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Mar 22, 2011
    Yes, that is optical lens and if cleaning didn't improved then I'm afraid optical lens is weak in performance and nothing can be done to improve it except optical lens replacement that is not feasible because new dvd player would be available in that price.
    It is not any firmware issue nor any wrong settings problem, optical lens is just dying.
    Thanks.
    On power up, lens moves towards spindle motor (where disc spins) to get reset the sled mechanism then optical laser will emit (high red light) and lens try to focus by moving up and down for few times, if disc is there, spindle motor will start spinning and lens will start reading data on disc.
    If no disc on spindle motor, lens will stop focusing and unit will show No Disc.
    This is the sequence in brief, how dvd player works.
    Correct, lens will start reading data located inward and moves outward to keep reading. Now if lens block does not move then it is problem of sled motor or related drive circuit. Sled motor moves lens block left to right etc, please check sled motor may be stuck for some reason.
    It sounds problem is in electronics circuit that drives/ provides volts to sled motor. It calls Servo Section.
    Schematics of player is required to sort out bad parts to get them replaced.
    Thanks.
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
Need remote code
try this method THIS METHOD WORKS FOR THE CH-DVD 300, CH-DVD 300S, AND CH-DVD 320
1. Switch player on, making sure that there's no disc in the tray.
2. Close tray.
3. Using the remote control, key in the following: MENU, 1, 9.
4. A menu will appear with the region option near the bottom of the screen.
5. Press ENTER, enter the desired region (0=REGION FREE )AND PRESS ENTER again to save the desired region.
6. Press OPEN/CLOSE. Hope this helps you with your problem
May 02, 2009 | Cyberhome CH-DVD 300 DVD Player
CyberHome DVR 1200
Main drive motor that spins the dvd replace with generic, when the motor gets old contacts get
corroded or woren out, ive taken apart and cleand sucessfully for a nother year on the motor.
or purchas another, the dvd must spin fast at the start, ive owend 3 of these pups for about 7
years. its the drve moter the lasers are good and strong.
Mar 01, 2009 | Cyberhome CH-DVD 300 DVD Player
Won't read/initialize CD's or DVD's.
Check for a dry capacitor on the power suply is about 16v 470mf you can identified him because the top are inflate.
Jul 01, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 can't read CD
Why don't you call manufacture and see if can get service.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
"no disc"
unscrew the unit try to clean the lense..this will fixya
Feb 04, 2008 | Cyberhome CH-DVD 300 DVD Player
Some DVD's load, others not
Does the DVD that are not loaded are original DVD? If they are not maybe your DVD doesnt know to read does new formats. DVD players become old very fast since every few monthes there are new DVD formats like: xVid, Divx, new and etc.
Mar 12, 2007 | Mitsubishi DD-6030 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
939 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
