Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
The "Drainage blocked" message appeared - how do I
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your post,
this is usually associated with a plugged drain or pump as you mentioned.
These are the steps I'd suggest you take to move forward...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) The
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful...I usually cover the edges with electrical or duct tape or wear welders gloves).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by handThe "Drainage blocked" message appeared - how do I - macmarkus_32.jpg of pliers.
( you should also see a ring with a string attached, if you pull this the door shoulThe "Drainage blocked" message appeared - how do I - macmarkus_31.jpgetting the water out first is usually a good plan )
macmarkus_31.jpg THIS RELEASES THE DOOR LATCH IF PULLED
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pThe "Drainage blocked" message appeared - how do I - macmarkus_28.jpghe filter/trap.
Hopefully you'll find The "Drainage blocked" message appeared - how do I - macmarkus_29.jpgthat initiated your post here.
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Mar 20, 2011
  • 2 more comments
  • zinniapath May 02, 2011
    Worked well and fixed the problem. Thanks. (I found a knee high stocking in there!) Please indicate in your post that the sharp edge is not on the cap itself but rather the metal of the machine cabinet . I didn't realize this and got a rather severe slice while trying to get the cap to start to turn. Pliers were required to pull the cap out once it was completely unscrewed as it is difficult to get a good grip.otherwise.
  • stuwecker May 31, 2011
    Excellent instructions!! Found a sock in there that tried to get away!! Thanks so much.
  • Hairdoctor24 Jun 03, 2011
    Dryer sheet..... The cap leaks now.... any advice
  • coffeebean82 Jul 25, 2011
    Perfect! It was pennies. Only forgot the part about the edges being sharp. They are not kidding!
Came up on display f10 and wont work
Hi dear,
F10 error related to OVER FILL. Follow the things below,see how it works.Thanks.
Troubleshooting
Error messages If an error occurs during the program, a message
is shown on the display. To exit the message after
taking action, turn the machine off and then back
on.
The error messages that may be shown in the
display are:
F10 Overfilling
1. Shut off the water tap.
2. See "Drainage error".
F11 Drainage error
Check:
• that no objects are stuck in the drainage hose
outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump. See the "Care and
maintenance instructions" chapter.
• that there are no kinks in the drainage hose
After taking action, run the Drain program or press
the Door Opening button (key symbol) to empty
the machine. If this does not resolve the problem,
call the Customer Care Center.
Jan 27, 2016 | Asko Washing Machines
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
hose outlet.
objects. Clean the pump (see the
"Care and cleaning" chapter).
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
Bosch exxcel f18 error. Machine runs cycle but will not drain water. Have emptied and unblocked pump on front and checked drainage hose.
according to what i find on google, it's a drainage fault, drain manually and check filter...ALSO CHECK OUTLET PIPES FOR ANYTHING BLOCKED IN IT
Dec 29, 2013 | Kenmore Washing Machines
Washer does not drain water
The major reason for this to happen is the clogging of the drain pipe of the washing machine. If, even after you clean the drainage hose, the problem persists, there may be other problems.
Next possibility could be that the drainage pump which drives the water out of the drainage hose may be clogged! So, remove the drainage pump and clean it. That should solve the problem. it might also be that the belt of the drainage pump motor may have loosened. If this is the case, you have to simply tighten it.
Take care.
May 30, 2010 | Whirlpool LSR5132PQ Top Load Washer
Agitates but wont drain
Take care
May 30, 2010 | Kenmore 22422 Top Load Washer
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
Message: drainage blocked
scgawlik,
Happy to assist you,
You said,
The pipe in the back is not clogged, it is wide open. When we removed the cover for the pump in the front and open the valve, the water obviously drains out. However, when you put it back together and try to run it, it will go through a cycle and when it gets near the end of the cycle that when the message appears drainage blocked and won't drain.
The electronic type washers , can be unplugged and after 5 minutes restarted and the system is then rebooted. This resets the system and clears the codes !
If the drain is not blocked then you have a faulty sensor or a bad pump
Sep 14, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Dishwasher doesn't drain
how do you check to see if the pump is pumping? The drain is not clogged or blocked and the line is not kinked. The garbage disposal is not clogged either.
Oct 06, 2007 | Dishwashers
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
658 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
