Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
My computer starting having harddisk errors. I removed my seagate freeagent go drive. I docked it to another computer, but it does not show any files on it. chkdsk says it is ok, and it still shows part of the disk used, but I cannot see the file structure. Any help? thanks!
    Genius:
  • 1,325 Answers
Hello
unplug both cables from the computer and form the AC outlet, for 1 minute.
follow tehse steps
1) plug AC adapter into wall and other end into seagate drive. leave it for 1 minute
2) after 1 minute is up, plug USB into seagate and then other end into computer. wait 10 seconds.
the drive will be recognised by computer.
Posted on Mar 20, 2011
Seagate backup plus is beeping and will not pull up on computer??
Troubleshooter: Seagate Manager does not see my Seagate FreeAgent drive Troubleshooting in case the Seagate Manager cannot detect the FreeAgent drive.
Sometimes, Seagate Manager (the software bundled with newer FreeAgent drives) does not see the drive.
This article focuses on drives that can be seen in Windows, but are not seen in the software.
If you are using Windows 8, please note that Seagate Manager is not supported in Windows 8, so you will need to use a different backup solution.
If the drive is not detected in Windows 7/Vista/XP, then use the external drive troubleshooters to try to resolve the non-detection issue.
After connecting the FreeAgent drive, please give it up to 1 minute to display in the middle of the main screen in Seagate Manager.
If the drive does not display, open My Computer (Computer for Vista) and confirm the drive is listed there. The drive should be listed as "FreeAgent Drive". If you have formatted or renamed the drive, then it will show up with the name you provided.
If the drive does not display in My Computer (Computer for Vista), use the External Drive Troubleshooter to help resolve that issue before continuing.
If the drive is detected in Windows, check if the Seagate service is running.
  1. Right-click on the My Computer (Computer for Vista) icon.
  2. Choose Manage.
  3. In the Computer Management window, click Services and Applications.
  4. Open the Services area.
  5. Scroll down the Seagate Service (they are listed alphabetically).
  6. The Seagate service should display Started in the Status column.
    If it does not, right-click on the service and choose START.
  7. If the service reports as Disabled, enable it to start automatically.
    To do this, right-click on the service. A Status Type drop-down menu will appear. Click on the General tab. Select Automatic and click OK.
  8. Reboot the computer.
  9. If the service fails to start after you reboot with these settings, then check the logs of your Antivirus or Antispyware software to confirm they are not restricting the startup of this service, as some aggressive protection programs can prevent services from starting until you approve them. So, you may need to approve this program specifically in the Antivirus/Antispyware software. Please contact your anti-virus software support for help.
  10. If the service will not start or is working already, uninstall the software (for steps on uninstalling the software, see this article).
  11. Once the software is uninstalled, reboot the computer.
  12. Then reinstall the software by opening the InstallSeagateManager.EXE file on the FreeAgent drive. If you have removed the software from the drive, it can be downloaded from the download center.
  13. If the drive is still not seen by the computer, connect the drive to other USB ports on the computer.
    Some eSATA cards block the drive's identity and prevent it from working. Updates have been made to Seagate Manager and to some vendors' eSATA drivers to help this issue. See our eSATA tips article for details.
  14. If the drive still does not display after these steps, please contact Technical Support.
Check Required Windows Component Installations
1. Check to make sure you have the MSXML Parser 6.0 installed:
  • Open Control Panel
  • Open Add/Remove Programs / Programs & Features (Vista)
  • Check box for "Show All Updates"
  • Look for "MSXML Parser 6.0"
If this is not found, visit Microsoft's website to install this component: http://www.microsoft.com/downloads/details.aspx?FamilyId=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
2. Make sure Microsoft .Net Framework 3.5 installation
  • Look for "Microsoft .NET Framework 3.5".
If this is not found, visit Microsoft's website to install this component. 3. Try the steps listed here.
4. Remove the Seagate folder from C:\Documents and Settings\All Users\Application Data (XP) or C:\Program Data folders (Vista) and reboot.
5. Download and install the newest Windows Installer.
6. Download newest Seagate Manager from our Website and re-install a clean copy. Note: Do not do the update when the message pops up saying one is available.
Jul 24, 2014 | Seagate Backup Plus 500GB 2.5" Blue...
Seagate Freeagent goflex not detecting
It sounds like the drive is failing. So you will need data recovery services.
A remote service is http://FreeDataRecovery.us
Aug 29, 2012 | Seagate FreeAgent GoFLex 500GB...
How do i find the files that have been saved on my seagate freeagant goflex desk 2TB drive
Hi there babyface,
You just have to plugin your Seagate FreeAgent to your computer's usb port using the usb cable. Once plugged in power the seagate on and your computer should pop up a notification, usually in the lower right corner of your computer screen, saying that it has detected a new USB device. Next, right click your Windows Start button and choose Explore to Open Windows Explorer. Once the window opens, look for the drive letter associated with your Seagate FreeAgent under "My Computer" or "Computer" located on the left pane. Click for that drive to show the contents on the right side of the window. Thats it!
If you need further assistance, please let me know. Thank you for using FixYa.
Jan 06, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Seagate freeagent go 250 gb. was working fine for
which files.... if you have "show system files" selected in your folder options in your operating system it still won't let you open them as that is it's way of preventing you from deleting or changing them
Jul 13, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Sep 17, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
The light on my Seagate freeagent go flashes quickly when it is connected to my computer, indicating an error. What should i do?
I had similar problem recently. I noticed that I had forgotten to connect the power supply cable to the USB hub, to which my FreeAgent Go was connected to, after I had connected all my USB devices to my computer's USB ports (after I had disconnected everything from my computer in order to isolate another issue). Reconnecting the power supply cable immediately stopped the flashing light and windows recognized the drive.
Don't know how you are connecting yours to the computer i.e. via a USB hub or directly to the computer's USB port. Note that my FreeAgent Go drive requires both USB connectors connected to the computer (or to USB hub). Two USB connectors are on one end and the other end of the cable is connected to the drive/docking station.
Hope this helps.
Jul 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I can't use this as a bootable device with Windows XP.
Dear,
Not every PC is capable of booting from a USB flash drive. For the most part, computers manufactured within the last two years are generally able to boot from a flash drive. Older systems may require a BIOS update, or might not be able to boot from a flash drive at all.
Drive must be formatted with FAT file system.
For your systen you need an internal Hard drive.
Regards,
Rakesh Kumar
Apr 08, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Drive manager is grey and says that no drive is attatched.
You need to get a Seagate Harddisk Utility software to check the disk intergrity.
Although hardware issues like can sometimes be very difficult to fix due to the impact on a volatile component on the harddisk which are most times not replaceable
Apr 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Urgent : 2.5" Seagate External HardDisk USB2.0 Problem
hi there have you tried to boot to bios and selecting the device from there and save and reboot and see what happnes
Dec 29, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Reformat seagate 120gb portable harddisk - freeagent
Hi johnsil,
If the drive shows up in MY COMPUTER then the easy way to format the drive is right-clicking on it then choosing FORMAT. This will erase everything in the drive, so make sure to back up everything in the drive before formatting it.
Now if the drive doesn't show up in MY COMPUTER you may have to goto the Control Panel click on Administrative Tools then select Computer Management then click on the category of "STORAGE", you should see there Disk Management. Carefully look there for your Seagate 120GB Freeagent drive, right-click then choose format, and that should format the drive.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
49 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
