Question about Sunbeam SBM1000 Microwave Oven
Our cook button won't work.trying to put in time & hit cook, won't turn on
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
When you push cook time and a time, or just hit the auto 1,2,3,or 4 minutes, it lights up on the display like it is cooking, with the timer till finished going and everything, but it does not actually...
Highly likely your microwave has "failed".
Down inside the microwave is a part called the Magnetron. This is the part, (about the size of your fist), that makes the sound waves to cook the food.
On some models, it can fail, whilst all the other stuff works.
3 possibilities:
1) You need a fuse replaced.
2) You need a capacitor replaced (That part "starts" the magnetron) or
3) you need a new magentron.
In any regard, very often people will not opt to have it repaired, because the labor & parts can cost more than a new Microwave.
God bless your efforts.
Sep 08, 2017 | Jenn-Air JMC8127DD Microwave Oven
Howm do I reduce power down to 50%
First enter the cooking time just like normal, but then you hit the power button and then hit the digit indicating the power level you want. THEN hit start and it will start cooking.
Mar 08, 2009 | Danby DMW119 Microwave Oven
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
Jan 10, 2008 | Sanyo EM-U1000W Microwave Oven
Comes on when you open door, and now it finally quit working
I think you've put up with enough hassle from this unit and should get another one. Intermittant flakey problems are hard (read expensive) to fix.
Dec 29, 2007 | Panasonic NN-S962 Microwave Oven
Sunbeam SBM1000 Microwave Oven Logo
26 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
