Question about Dell Inspiron 5150 Notebook
Power on and Battery led's blinking and nothing else .Remouved rams and HD tried again , same problem.remouved battery,same,checked power suplly and it 19.5vdc OK Please Help!
  • 35 Answers
WHEN U POWER THE POWER LED IS GREEAN ???IF NOT HAD PROPLEM WITH CONNTROLER OF POWER HAVE SOME HAD TO POWER
Posted on Mar 21, 2011
Hp probook 6455b will not turn on why?
Take everything out of it that you can. That would mean the ram and drives, see if it boots. IF it does, then put the ram back and check it again. If it does put the hard drive back etc. If you get to the point that it wont boot with nothing installed then it could be a dead cmos battery or a loose CPU or something like that or a bad mother board.
Apr 04, 2016 | HP Computers & Internet
Hello guys. I need help with my hp dv4 1225dx pavilion. It all started with not powering with battery power. But the battery is in perfect condition. When I plug in the power cord. It comes on and I...
It sounds like a hardware issue, if you're getting the LED's blinking when pressing power, there IS power to your mainboard (which is a good thing). Some manufacturers have placed LED blink codes within the system to let you know what's going on, but I have a feeling it's either A) your battery or B) your hardware, such as a bad RAM stick.
Try removing the battery and with the power plug connected switch the laptop on. If it works, you've got a bad battery.
Try removing a single RAM stick or replacing both.
You could search HP Pavilion LED blink codes to further address the issue.
Jul 18, 2012 | Computers & Internet
Compac Evo N610c - 2Mhz - 1 GB ram - Windows XP SP2 Blinking charging light went out and computer won't start up again. Checked power suplly (18,57v dc) Replaced with another power supply, replaced the...
Your computer has an open circuit on the system board. If you have data on the machine you can remove the hard drive and connect it to a PC, Sorry I can't think of a more elegant solution. I hope I'm wrong.
Mar 11, 2011 | HP Compaq Evo n610c Notebook
Averatec 3150 will not boot. Blue LED blinks
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 09, 2010 | Averatec 3200 Notebook
Sony vaio pcg-k33p Won't power up
I had one with the same symptoms, the way i fixed it is by taking it all apart and resolder the system chasis grounds on the mother board, then reseting the motherboard's memory battery. A bit complicated for those with little knowledge on computer repair. You may have to take it to a computer shop, or try fixing it yourself. It took a while to figure it out.
Feb 11, 2010 | Sony VAIO PCG-K33P Notebook
I have ACER ASPIRE 2920, the power suplly can't turn ON
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Will not boot up
I have seen a lot of Toshiba Laptops with bad "DC Connectors" on the motherboard. It sounds like you know what your doing so here a link on how to disassemble your laptop.http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
and here is another on how to repair the dc connector. http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
May 27, 2009 | Toshiba Tecra M2-S530 Notebook
Shuttle X PC - HD + Power LEDs briefly illuminate, no boot.
It sounds like you have a bad power supply. It will store up a very small amount of energy (enough to run some LED lights) but not enough to power up the system. That's where I would look. If that is not the problem, then I would look to the capacitors on your motherboard. Good Luck!
Dec 02, 2008 | Shuttle Computers & Internet
Memorybattery.
This battery is a high voltage coin cell type (has a battery and a capacitor combined) i believe it is a series dsk check the bottom right of this link; http://www.elna-america.com/products/dynacap/dynacap_frame.htm and you can see a drawing to check it is the right one. contact details are all there. I would expect most electronic hobby shops to be able to get these for you if you don't want to go direct. Hope this helps :)
Nov 26, 2006 | Garmin GPSMAP 60CS GPS Receiver
Dell Inspiron 5150 Notebook Logo
48 people viewed this question
Alun Cox
