Question about Cameras
It fills up with just 3 or 4 shots - Cameras
  • kakima Mar 20, 2011
    What make and model camera? Do you have a memory card installed? If so, what type and size? Is the card formatted?
  • 4 Answers
Reduce resolution of pictures or get a bigger memory card
Posted on Mar 21, 2011
Cimbali m29 selectron 2gr espresso machine. power outage from electrical source. when power was restored, tank heats up and comes to pressure, however no water will dispense from heads...
* You will need to program groups again.
* I'm surprised I did not record and upload a programing video *sigh*
Oh well, somebody did it already:(check at 3:57 on the following vid)
https://www.youtube.com/watch?v=0-3SbS-PU4Y
* Set up each shot with a filled portafilter (for the appropriate dose setting. Single for single, double for double, etc.)
* Press and hold "Stop" button till it light (and/or beeps). Release stop button
* press and HOLD the appropriate dose button (within 5 seconds or it cancels out)
* Watch the coffee dose as it pours out into cup or a shot glass (for accuracy)
* Release the dose button just before it hits the desired amount. You may have to do this several times to practice.
* Continue with setting the dose on the other settings (long, double, etc.)
* Note; you can set the "least used group" as in a 3 or 4 group head machine with specialty doses. Like a triple if you have the proper portafilter for this shot. Or an "American" long shot (though I don't recommend running 6-8 oz of water through a single coffee dose. Though I have found some shops using drip coffee through a triple basket and very long dose to fill mugs. They didn't want to get a regular 12 cup brewer.)
* There are other dosing tricks like copy over to other groups. But I've found that setting each group and dose is good practice. (and I have to do it several times a day as a Espresso Tech.)
Aloha, ukeboy57
Aug 09, 2017 | La Cimbali Coffee Makers & Espresso...
Hi just wondering how u caliberate a esspresso shot on a La Cimbali M23 machine. all heads only run for half of a second.
* You will need to program dosing on each group head.
Aloha, ukeboy57
Jul 31, 2016 | La Cimbali Coffee Makers & Espresso...
D-link shots down connections 3 times a day
hi
Try the modem on anather computer
If the problem still exist - i have a filling that the problem is comming from the internet provider
bernard
Aug 03, 2012 | D-Link 802.11g Wireless Router WBR-1310...
My Talea touch plus is struck in the cleaning cycle after a de-scaling.
Normally it drips at the beginning and then becomes a steady stream throughout the shot. The truly determining factor is how fast the shot is coming out. You want to get 2 to 2 1/2 ounces of espresso in 20 to 25 seconds. If it's coming out that slow it's going to be a lot longer, and odds are the grind is still a touch too fine still. Sounds like you need to just tweak a bit to get an even better shot. Also, keep in mind with the Saeco supers, there is a 2-3 shot delay in changes you make in grind before it makes an effect.
Jul 22, 2012 | Saeco Talea Touch Plus Automatic Espresso...
Where do I fill the transmittion fluid on an audi a 4 2001 i axidentally loosened the wrong plug.
First, check the owner's manual. If you don't have it or can't find the right section.....
Not particularly familiar with Audi's, but like any other car there is either one of 3 things.
1 and 2) a fill tube or dipstick that goes up to the top of the engine or 3) a fill bolt on the transmission.
If either 1 or 2 is true, get a funnel and fill appropriately. Otherwise there is a bolt, somewhere on the transmission - higher than the drain plug. On some cars, the words "DRAIN" and "FILL" are forged into the transmission next to these bolts. They are hard to spot, you'll need good light.
If you don't see a label, try to find a bolt similarly sized to the drain bolt - again it will be higher up. If it looks like it doesn't hold anything together, give it shot. You've already drained the fluid, the only other thing you could do is disconnect something - in which case, put it back without touching it. If you see a big hole into the transmission and nothing else, grab some xmission fluid and fill it up as high as you can - until it leaks back out the fill hole - then plug 'er up.
Mar 01, 2011 | Audi A4 Cars & Trucks
X1 trio makes huge shots, at the 3rd position it will nearly fill a coffee cup, at the middle it makes a double (about 4oz, and so on. What is wrong with it
Hi
The trio is set up for pods. There is nothing wrong with it. The positions on the brew head are for different shots. The 3 rd position lets a lot of water through, and the 2nd one lets less and the first one lets the least water through, and makes the strongest coffee.
Apr 19, 2010 | FrancisFrancis! X1 - Stainless Steel...
Excessive water poured through shot
its possible someone held the buttons down to long enabling program mode.
Go to your local market and purchase a 3 ounce measuring glass. Place it where you place your coffee cup and hold down the small button, it should enable program mode. Stop it once it reaches 1 ounce or your desired amount.
Do the same for the large.
Sep 03, 2009 | Saeco Royal Professional Espresso Machine
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Cameras Logo
12 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
