Question about Siemens 24 in. SE55A560 Built-in Dishwasher
I have a hiDefinition, Top button(Hidden when you close the door) with a stainless steel front cover. Drain pump continuously runs and won't shut off. This will not allow the washer to go into the next cycle or into the dry cycle. This I guess would be the shut down mode allowing the built up heat to dry off the plates and glasses.
    Master:
  • 330 Answers
Unfortunatley this is a error code to let you know the main computer board has failed & needs to be replaced.very common with electronic washer's just the part will cost around $300 add labour it will cost at least $400 to repair GOOD LUCK
Posted on Mar 20, 2011
When I push auto and start the lights go on and the time, but then it goes off. Why?
Hello. Is this unit less than 1 year old? If so, anything defective is covered under the warranty(parts and labor). After 1 year, certain parts are covered, however, no labor is covered. Make absolutely sure the door is closed properly--there is an internal door switch that must be closed(tells the main board it's okay to start the cycle) or nothing will happen and produce the exact symptom you describe. Next, the unit could be experiencing an error condition causing the shutdown. Make sure the water supply to the dishwasher is turned on(and always run the hot water in the sink before starting the dishwasher to ensure hot water gets to the unit). Next, do you hear the drain pump working? A lot of dishwashers turn on the drain pump immediately to remove any standing water in the pump before letting in fresh hot water. If the drain pump is jammed or clogged, you might hear a soft humming sound only(from the motor trying to spin) and then the dishwasher will shut down due to it detecting a malfunction. Check the float switch in the tub to make sure nothing has gotten underneath it(ex. a spoon or fork can become lodged underneath and the dishwasher thinks there is already water inside and won't fill) I hope this helps you!
Oct 12, 2015 | Maytag MDB4949SDH MDB4949SDH Dishwasher...
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
The interior lights wont turn off. they melted the old light bracket so i replaced it and the lights still wont go out
It sounds like you have a switch that isn't closing when the door shuts. I'm not overly familiar with the LG's, but looking at the Sears Parts Direct site, it looks like the door switches are in the hinge covers on top of the unit. There should be two of them, one for each door. But, only one has to not be working to keep the light on. The first thing I would check is to make sure the hinge cover isn't loose or out of position. The switch should close when the door closes. If the hinge cover moves, then the switch won't close. If everything is tight and aligned, then one of the switches is bad. That can be checked with a volt meter that does continuity checks. Unplug the unit before checking because those wires should be hot at all times. If you don't have a meter and want to do trial and error, just buy one switch since they both are the same. Here is the parts diagram showing the switch locations and part numbers:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX25960ST/3204/0161000/K0810255/00001
The switch is 402A on the diagram, located on top of the box. If you click on the parts diagram, you can enlarge it to get a closer look.
The switch part number is 6600JB3007E
Hope this helps
Aug 11, 2011 | LG LFX25960ST Stainless Steel French Door...
In the middle of washing it shows 0E and shuts off. I open and closed the door it start working and does the same thing and middle of washing again. What is wrong?
Hi, it is a Drain Error OE
Which means it is not fully drained out in spite of 5 min. drain operation
The Drain Hose kinked or blocked. The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled.
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Jun 22, 2011 | LG LDF6810ST Stainless Steel Built-in...
How do I access gears in a200 hobart. I don't see any screws to detach top. top looks painted shut.
There are two screws holding an access cover on the top front half of the mixer. These screws are normally plainly visible - has it been repainted heavily enough to hide the screws?
If you can't see the screws, all I can say is they are there, under the paint. Maybe shine a flashlight accross the top front half at an angle and look for a hint of a slotted screw head in the paint.
I'm not sure what the access cover is made of nor am I certain if the screws are stainless steel, but if the cover is aluminum and the screws aren't stainless steel, then a magnet should be able to locate the screws for you.
The screws a usually a domed-flathead screw, so some very close inspection of the paint surface may show a slight "bump" where the srews are.
Nov 14, 2010 | Hobart A200 Stand Mixer
Pump running non stop.
On the left hand side of the dishwasher (looking from the front, open door) there is the water inlet port. Behind it is a float assembly that determines how much water is in the dishwasher and how much it needs to add or pump out.
If you pull the outside, panel, you will see that float assembly. Check for loose connection. Since you are getting no error codes, if everything looks OK, I recommend either schedule a service call or replace that assembly. If problems continue, the main controller board (PCB) is the next most probable cause.
Please report back with what you find. Thanks!
Apr 06, 2009 | LG LDF6810ST Stainless Steel Built-in...
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Siemens 24 in. SE55A560 Built-in Dishwasher Logo
373 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
