Question about Epson Office Equipment & Supplies
I have a epson photo R300 the ink and paper light is blinking. I put all new ink in it and when i get the ink in it says "printer parts at end of service life" then i can;t do anything up shut it off
  • 1 more comment
  • jplscl422 Aug 03, 2008
    why would it say it is athe end of its service life
    i hve reinstalled my ptinter program and still nothing has changed
    i have had the printer for abot 4 1/2 years. I pressed the stop and power button for 10 seconds it shuts off and when i turn it on it is still the same.
    Brigadier General:
  • 6,966 Answers
If I may add or an alternative...
Assuming no hardware problem and/or be it end of life, there is a software utility for most Epson printers that is intended to restore the printer to all factory default settings (including end of life). It is SSC Service Utility for Epson Stylus Printers. Information about the utility may be found here. The download is here. Your particular model number may not be included but it may be worth your while to still download, install and check.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
  • 1,183 Answers
The printer has reached EOL ie end of life . The best resolution to your problem would be to replace the printer. You would be able to get a decent all in one printer for under 65$.
Thanks
Proton
Posted on Aug 03, 2008
  • 594 Answers
Here is the link to your printer..
http://files.support.epson.com/pdf/r300__/r300__u1.pdf
copy and past it into your browser.
go to the trouble shooting section and it will tell you how to do a printer check on it's self.........
I have the same printer and this fixed the same problem you are having.
  • Epson Master
  • 13,433 Answers
Just one question first before I give you a solution, how old is the printer?
  • 1 more comment
  • Ekse Aug 03, 2008
    it appears to be a waste ink counter, the waste ink needs to be emptyed / cleaned or replaced
    ones that is done heres how to reset it
    Press and hold 'stop' 'maintenance'(ink button) and 'power' buttons for about 10 seconds,(while printer is on) a message will come up on the screen saying counter is reset and to turn off.
    turn the printer back on and it should work.
    You can try this even without cleaning the waste ink but I recommend you contact espon about the waste ink replacement service or instructions on doing it yourself.
    I suspects is a failry easy job.
  • Ekse Aug 03, 2008
    solution by a trinzo
    Service Required Parts Inside your printer is at the end of service life.This message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable live.
    The best solution that we can advice regardding this error message are the following:
    1. Download the Epson Ink Pad Reset Utility at http://www.epson.com/ipr
    2. Since the ink pad is full. It is recommended to send the printer to the nearest authorized epson service center.
  • Ekse Aug 03, 2008
    In that case use the
    Epson Ink Pads Reset Utility
    Sergeant:
    Champion:
  • 310 Answers
Just hardly restart the printer.........And the try it if its not work means reinstall the printer software........
    Guru:
  • 1,894 Answers
Then i think there is some part broken in the printer internally.
please have a manual check sir
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Epson Stylus photo R230 Desktop : Printer icon flashing with exclaimation mark `No Ink` changed Black Ink cartridge in printer , Red & Green lights on not flashing Please help.. how do you know which...
go to the printer setting under control panel, right click on the icon then properties..you can check the ink level there...normally if your printer blinks and ask for a new cartridge..better follow what the printer says... : >
Aug 31, 2009 | Epson Stylus Photo R300 InkJet Printer
Red light is plinking
this mean that your printer waste pad is full and your printer needs to be reset go to this website http://www.ssclg.com/epsone.shtml
this will reset your printer
plz rate me
Mar 23, 2009 | Epson Stylus Photo R300 InkJet Printer
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Mar 10, 2009 | Epson Stylus Photo R200 InkJet Printer
Service ink reset error epson R265
Try to find out how to completely reset your machine through your manufacturer
Feb 27, 2009 | Epson Stylus Photo R300 InkJet Printer
I have an epson photh R300. The ink and paper light blinks. i put all new ink in it and it says "printer parts at end of service life." It won't move or do anything after that all I can do is...
the printer's counter shuts the printer down after "x" number of prints, since the ink-pad is typically saturated with excess ink at that point. You won't have to take it to get serviced if you simply blot the excess ink from the ink-pads and reset ther counter. To reset the counter, download this program and install.
http://inkjetprinterhelp.us/epsonSSC.html or http://www.ssclg.com/epsone.shtml remember to blot excess ink off the ink-pad, and then follow the instructions to reset the counter. Good luck!!! JohnsGroovyWebsite.com
Aug 02, 2008 | Epson Office Equipment & Supplies
Epson R300 printer leaking blue ink on rollers
Hi , clean both end of roller clean rug or cotton tip , this may happen during cleaning time some ink expose both end of roller sometime in piece of paper .during the cartridge in the middlle pullout the power cord stop cartridge and push cartidge down and lock.
Jan 29, 2008 | Epson Stylus Photo R300 InkJet Printer
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
