Question about GE Dishwashers
My GE Monogram ZBD 7100 dishwasher starts in normal mode but then switches to china crystal mode and stops,
zeusfaber
  • 247 Answers
SOURCE: GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Posted on Apr 22, 2007
  • 77 Answers
SOURCE: Water not draining from GE Monogram
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
Posted on Feb 05, 2009
SOURCE: GE Monogram dishwasher
I think I had and now have again the same issue. I called a repair man who replace the entire control panel. He state the moisture caused it to blow out. The moisture???? it's a dishwasher. Well a year later the problem has returned. I can only use one setting at this point.
Posted on May 21, 2010
rickead1
  • 1998 Answers
SOURCE: The Normal wash cycle won't light up. Only china
does the normal wash cycle work though sometimes a ligt might be gone on the control if the wash cycle doesnt work then your in for some headahces unfortunatley you would have to be able to diagnos which is the problem either the main control or the touch pad it all depends on how old the unit is ive seen both of these go you can find the part online at marcone appliance parts if you have a problem diagnosing which it is please call a technician and they will be able to tell which one is malfunctioning
Posted on Jul 13, 2010
  • 506 Answers
SOURCE: How is the china and crystal wash cycle different
Most dishwashers that employ this setting use a lower temperature for the water and also they do not use the element to dry the dishes, they are air dried. China and crystal are very sensitive to changes in temperature and can crack easily. They should always be washed by hand however if you have to use the dishwasher make sure you have a mild detergent. No bleach or acid should be contained. If it says citrus anything it has acid in it. Also use half the amount of detergent regardless of its strength. Hope this helps. Good Luck!
Posted on Jul 19, 2011
Why does my GE Monogram dishwasher keep blinking in rinse hold mode
either the water will not drain due to bad water pump or restriction, clean clear or replace
Aug 21, 2014 | GE Monogram® ZBD6880NSS Stainless Steel...
How is the china and crystal wash cycle different from the regular cycle on my GE Triton XL dishwasher? Can I use regular dishwasher soap on my china and crystal?
Jul 19, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
Which is the best powdered cascade product for the china/crystal setting on my miele?
Most european dishwashers are water conserving and energy saving. You have to be very careful in the type of detergent that you use. Plain, original cascade powder works fine in your Miele. Use 1/2 of the recommended amount, as your dishwasher uses much less water than the american machines that the amounts are written for. avoid cascade with additives such as bleach, or dawn. these additional components in the detergent do not rinse off well with the reduced water quantity, and will leave a gritty white residue on your dishes. Stick with the plain powder. I use Finish tablets with the red powerball, and I dont add rinse aid. These tablets work great in the Miele, asko, Bosch, and other imported dishwashers.
One caution on your china and crystal setting, your manual states that if you want to use the china and crystal cycle, the dishwasher should be connected to cold water only. The temperature of the china and crystal setting is limited to 115 degrees. your hot water is probably much hotter. if your dishwasher is connected to hot water, it will defeat the purpose of the lower temperature cycle. you will get etching on your crystal glasses.
Remember, the Miele will heat its own water one batch at a time. Connect it to cold for energy efficiency, hot for shorter cycle times. but cold only for china and crystal.
Enjoy your machine.
Nov 18, 2010 | Miele G2183SCSFSS Builtin Dishwasher
Water remains under the 4 inch plastic trap thru which the water exits the dishwasher. It stagnates there, resulting in terrible odor. What is the cause and what is the solution? Model # ZBD 6880K...
First make sure your homes drain pipe is not plugged up. If not remove the drain hose where it connects to the drain pump. you will see a flapper valve(thin rubber piece) #328 in the diagram,this is probally allowing water to flow back into the machine. A common problem with this model the flapper gets torn or worn out. They are inexpensive and easy to replace. Enter your model # at www.appliancehelponline.com and diagrams will come up for your model.
Nov 05, 2010 | GE 24 in. Monogram ZBD6880KSS Stainless...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
No problem just a question
the manufactor says yes but if its real china and crystal i myself would not take the chance / i would wash by hand, air dry and wipe with soft cloth ,,,, all dishwashers has pressure behind the water to clean so i would play it safe and not use it to do mine / larry
Nov 29, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE Monogram ZBD0700K - gel pak detergent not dissolving
Low inlet water Make sure inlet water temperature is at least
120°F (49°C)
Run water at the nearest faucet prior to
starting the dishwasher to insure optimal water
temperature.
Water pressure is low Turn on a faucet. Is water coming out
more slowly than usual? If so, wait until
pressure is normal before using your
dishwasher.
Air gap is clogged • Clean air gap.
Improper rack loading Make sure large dishware does not block the
detergent dispenser or the wash arms.
Jun 20, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
Dec 28, 2007 | GE Dishwashers
Dishwashers Logo
80 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
