Question about Holmes Products HFH111TU Compact Heater
Hfh111 heats weekly only on hi setting. Where can I get a schematic?
Hi I need the schematics for a Samsung air conditioner model aw06ecb7. It was falling out the window and I grabbed it by the cord and the whole control panel came apart No major parts were affected and I...
There should be a schematic on 2 of the electrical panels near the controls. Or possibly in the paper material that come with it when purchased. If those aren't available, you won't find it on the internet anywhere.
Mar 06, 2017 | Samsung Heating & Cooling
Stuck in stand by
Did you try disconnecting the TV from the power for a few hours to reset it?
Feb 08, 2008 | JVC LT-26C31 26 in. LCD Television
Will run but wont heat cant find schematic to find out which limit i need to replace
Depending on model but usually you take off back pane and on the right hand side is the element assy with a resetable hi limit , a little red button in the center of the hi limit and if that's the case chech your venting at the same time
Apr 16, 2013 | Bosch Dryers
I need a schematic of heating and cooling
There are many different configurations...to give you a proper schematic we need to know make and model number with t-stat make and model...
To shoot in the dark would only be confusing for you...
heatman101
Sep 21, 2010 | Heating & Cooling
Heating element does not come on when thermostat is set to heat. This is a Janitrol A49-10 air handler. Does anyone have some schematics for this unit ?
I do not have the schematic but if you take the upper door panel off and you will see what looks like a limit switch to the left and right. these are the fusable link connections to the heating elements. start there and that should be your problem
Dec 18, 2009 | Goodman CKL49AR49 Air Conditioner
Lost program instructions freezing
Hi, on a programmable stat, you should be able to raise the temp with the arrow and then push hold temp. feature. This will hold the desired temp and get you heat unless you have a stat problem. Try this and let me know the settings.If this didn't work, make sure the stat is in the auto-heat posistion. Push program and set the time.press again and set the day of week. Repeat this step and set the desired temp for each day of the week and week-end and push run program.You should hear it click on. It takes a min. or so on heat as there is a delay. Make sure the batteries are strong as they run the program. Let me no. Best of Luck, Sincerely, Shastalaker7
Dec 04, 2009 | Honeywell Programmable Thermostat Heater
Recently installed indoor unit and outdoor unit. Outdoor unit has not been wired yet. Installer said I could use indoor unit on em heat until it gets wired. Installed one week ago, now does not work. ...
Hi, wow I can't believe they left you with E-Heat only, running the blower with the heat strips on!! Like it says, for an emergency in the event you loose you're compressor. You say that know you have nothing.I would have to be on site to wire the condensing unit, High and Low voltage as this is a heat-pump and they all have different wiring schematics. Look at the indoor unit and find the power source.Being a heat-pump you should be at 220volts. Find the box it may be right there to see if a breaker has tripped. If so, turn it off and snap it back on.If this is not the problem, you need to get on the phone and have them back on site today, and if they are Licensed a/c Contractors and refuse to come out because its a week-end, don't take no for an answer, just bring up the State Contractors License Board. They should have a tech on call 24/7 as I was one on call until I became a contractor. Again, don't take no!! Best of Luck to you,
Shastalaker7
Nov 13, 2009 | Honeywell ER150B Air Conditioner
ICT222 pincushion issues do you have schematics?
Schematics are never available for free. In printed form, they are sold in bundles with those from several sets packaged together. This is why service technicians are the only ones who usually buy them. In machine readable form, they are available as part of a subscription database service; again, too costly for an individual.
Even with schematics, it is DANGEROUS to work on the inside of a projection TV. There are High Voltages which can persist for WEEKS after the set is turned off.
Even if you could find and replace the bad part, readjusting the pincushion settings usually takes special instruments. Unless you are planning this as the start of a new career, you had better call a service technician.
Oct 10, 2009 | RCA HD52W56 52" Rear Projection HDTV
Heater wont blow hot air anymore.
In all probability the heating element has failed and the cost to repair would be more than the cost to replace it. Inexpensive heaters do that over time.
Dec 01, 2008 | Holmes Products HFH111TU Compact Heater
Need service manual or schematic
Problem is on Amp Assy. Resolder transistors and regulators that are mounted to the heat sink and replace both convergence output ICs. Replace the existing STK392-110 ICs with STK392-180 for improved reliability.
Sep 11, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Holmes Products HFH111TU Compact Heater Logo
24 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
