Question about Garden
My Homelite electric cultivator stopped working. The motor hums, but the tynes don't move. The manual says take it to a service center, so I googled for that, and got you. do you know where the homelite service center is near Houston, TX?
SOURCE: homelite 4 cycle outboard motor parts
I have 2 homelite 55 HP for parts, every thing but rods, and in very good clean condition.
What do you need?
Tom Tompkins
Portland, OR
503-645-4227
Posted on Oct 22, 2008
SOURCE: I am looking for a homelite super 2 service manual
I have that saw. The manual states if you are using Homelite 2 -cycle oil read and follow the instructions on the package. If you use other than Homelite oil use 16 parts gasoline to 1 part 2- cycle oil, 1 gal / 8oz
Posted on May 26, 2010
  • 5 Answers
SOURCE: homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
2strokeguy
  • 183 Answers
SOURCE: My Homelite Mighty Lite 26b
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Posted on Dec 21, 2010
  • 46 Answers
SOURCE: homelite 26cc gas cultivator blades
This sounds like a drive belt problem. When the belt gets hot it stretches and and slips. You can check the adjustment of the tension pulley. If it is adjusted all the way to max tight you will have to replace the belt.
Posted on Mar 05, 2011
Tiller wont move forward
If its not self propelled you must push it tynes only dig they dont pull the machine forward a self propelled means it has wheels on the back of unit that is chain or belt driven
Mar 10, 2014 | Honda FG201
Cordless 18 volt lithium ion sawzall hums and clicks blade wont move
I don't know what model you have but Milwaukee sawzalls use a wobble shaft and wobble plate to turn the rotary motion of the armature into the reciprocating action of the blade. If you motor is working (hums?) but the blade won't move one or more of these parts are broken and hitting eacher (clicks?) inside the gear case. You or a repair center will have to take the gear case apart to find our what's broken and determine whether it's worth repairing.
Jan 27, 2012 | Milwaukee Tool Saws
2007 passenger folding mirror will not work
{: ) Have someone control the power fold buttons, while you check closely the passenger mirror. If you can feel or hear even a faint hum of the motor while commanded, try giving it a little help, but don't force it if you think it doesn't have enough power to extend or retract itself. The motor could be really stuck or inoperative.
Sometimes when the mirror has been accidentally or manually folded, it needs to be reset by just pressing on the fold buttons a few rounds and let the mirrors fold by itself. Like an exercise.
If you hear the humming noise whenever the fold buttons are pressed, we can assume that the circuit on that side is ok since it is responding electrically, and that a jammed or stuck mechanism is preventing it to move.
If you don't feel or hear any humming, as in totally no sign of response, then there will be additional considerations before deciding to go for a replacement mirror. You will need to confirm if the fault is on the wirings, a door module, or the mirror motor itself. A scan tool test may be recommended for effective diagnosis.
The power fold mirror can be serviced as an assembly. So, goodluck.
Aug 30, 2011 | 2005 GMC Yukon
My tiller stopped moving during use, after enitting a puff of smoke. The motor still works well; it does not move, however. Is there a belt that could be burned out? Is this something that can be...
You don't say where the smoke came from but check out the worm gear box and see if gear is eaten up. Supposed to be greased regularly but gear can wear out over time or overloaded digging. . Don't know your model but here is manual on one of them. See if it helps. Look fer it!
http://mantis.com/global/assets/owners_manuals/08_tillers/401702.pdf
May 14, 2011 | Mantis 2-Cycle Tiller
Can you adjust clutch 16"homelite electric saw
There is not a clutch on an electric chain saw, it is direct drive when the electric motor ia activated. If the chain is binding it will stop the chain.
Nov 03, 2010 | Homelite Electric Chain Saw
Homelite hedge trimmer , motor runs but blades do
What I did:
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
