Question about LG DLE3733 Electric Dryer
I have a LG DLE3733 elec dryer that won't start up. The power comes on, the check filter light is on and when you push the start button it just clicks. Thoughts?
  • 1 more comment
  • jjgolfhacker Mar 21, 2011
    What is the CCU and where is it found? The rubber seal around the lint trap started coming loose so I think that too much lint got into the machine....I read on other posts that they thought it would be a sensor, especially since the check filter light will not go off.
    One more thing, When you turn the power on it says Check Filter, then it says Cooling
  • jjgolfhacker Mar 23, 2011
    Had it fixed it was an excessive amount of lint in the dryer caused from the exhaust hose not being firmly seated around the exhaust tube of the dryer. The lint was being blown through that area into the dryer, where it tripped a lint sensor. Thanks Jerry
  • 1,998 Answers
Could be the door switch or could be the lint filter sensor another tech has previously posted on the repair for the lint sensor on this link click here http://www.fixya.com/support/t7724937-dle3777w_electric if you have any further questions or if after you do replace or repair the lint sensor you have any other issues or the dryer still wont start please message me back I try to achieve the highest possible rank that I can in all my chats it allows me to help other in similar situations Thanks Rick
Posted on Mar 21, 2011
  • Rick Ead
    Rick Ead Mar 23, 2011
    Thanks again jerry glad your unit is fixed if you ever have any further questions on appliances you can message me directly Thanks Rick
    President:
  • 2,468 Answers
Run the diagnostics tests on the unit from the "tech" diagnostics sheet inside the units case near the upper area,if this does not help,then start by powering the unit down at the wall plug if so equipped,or the homes power panel circuit breaker,then remove each and every cable connection (especially the ribbon cables) from the C.C.U. then replace each connection if they look O.K. ,then try re-powering the unit and if still the same,then replace the C.C.U. if no change in operation
Posted on Mar 20, 2011
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
LG DLE3733 loud vibration from bottom
If that vibration is while running it may be from an imbalance of the clothes in the drum. Open the door, when the drum stops reorder the clothes around the drum and see if the rumbling stops.
Jan 22, 2013 | LG DLE3733 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
LG dryer DLE 3733S control panel inop but light on in drum. 3 years old intermittent problem, is this electronics panel going bad? if so, do we replace PCB Main or PCB Assembly? Thanks!
Check the power to the display panel after you have it removed. If there is no power check the lines to the control, If the power is present with no action on the panel then you will have to replace the board. It may be as simple as cleaning the board off, since it has been a intermittent problem in the past. hopes this helps Tim
Nov 25, 2010 | LG DLE3733 Electric Dryer
Where are the fuses for a dle3733 dryer located, it wont heat
forget the fuses, you more than likely need heating coils.
Jun 20, 2010 | LG DLE3733 Electric Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
IT READS tEl in the timing area
tEI means that the thermistor has failed and needs to be replaced.  The filter light always comes on as reminder to check the filter before starting.  That cannot be changed.
Jan 29, 2008 | LG DLE2514 Electric Dryer
LG DLE3733 Electric Dryer Logo
203 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
