Question about Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
My Model number 11635923502 kenmore vacuum is making a deep suctioning noise as if something is stuck in it. We have cleaned out the filters and all the vacuum lines thinking it was clogged. It is still making this noise and we are frustrated as to what could be causing this problem. The unit does not have much suction.
SOURCE: Suction
i can think of 2 things first do"s the clutch{ if it has one}work or is it in the off postion you can test this by lying the dyson on it"s side and turning it on but remember to push down on the bottom as if you was hoovering if the brush spins then its ok if it dosen" move then replace it second take the bucket off and remove the bin tune it upside down and see if it is blocked if so the best way to clean it is to sit it upside down and put a hose pipe in then just wait till the water runs clean hope this is some use to you
Posted on May 22, 2007
SOURCE: suction
Check the handle tube for a collection of hair, paper, dirt.
Posted on Oct 23, 2007
SOURCE: Dyson Animal clogged
Here is the best way to clean your dyson that I have found!
http://www.crazysquirrel.com/diy/dyson/cylinder-clean-page-1.jspx
Posted on Mar 02, 2008
reddevil6
  • 1673 Answers
SOURCE: Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
Posted on Jun 01, 2008
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
Rattling noise beneath filter
Broken fan maybe. If the fan is has come loose from the motor shaft, it will rattle and there will be little or no suction. A trip to the local vacuum guy may be in order.
Oct 29, 2013 | Kenmore Vacuums
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Bissell 9500 2x deep clean (NO SUCTION)
Like everyone else (!) your lint filter is probably clogged. It is located on the top clear palstic section (the one with the dial to switch from tool to floor use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Flip the door open and you will probably find it is clogged with hair, carpet fibre., etc.. Clean it out and you should have suction again.
Feb 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Jan 26, 2009 | Kenmore Vacuums
Looud noise and no suction
the motor impella is blocked. you have to access this from the bottom
Jan 23, 2009 | Kenmore 34720 Upright Vacuum
Kenmore progressive upright canister vacuum
I had the same problem and so my husband took our vacuum apart. I cleaned what I could and discovered that there is a foam filter that sits below a dark gray cover immediately beneath the bag (on the floor of the inside of the vacuum). This is different from the HEPA filter. I cleaned this off (ours had a lot of dog hair on it) and placed it back in the slot. The vacuum is not making the noise anymore and the suction is even improved. I had not noticed the suction had deteriorated as the vacuum still worked well in my opinion. I hope that this helps and that you have the same problem. It was very easy to fix. I believe the noise was due to the impairment to the suction. Good Luck!
Sep 12, 2008 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Mar 15, 2008 | Kenmore 31912 Progressive Direct Drive...
Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue Logo
70 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
