Question about Garden
Saw shuts off during heavy cutting - Garden
  • 2,239 Answers
Fuel starvation, replace the filter in the tank, when it starts to die just try loosening the fuel filer cap, if it picks up, you need to replace the fuel tank breather.
Posted on Mar 21, 2011
How do I pick the perfect pole saw?
Want to saw up high, but think it's dangerous to saw on a ladder? Good thinking. So how can you get your saw to reach those high branches while keeping your feet planted on the ground?
Take a lightweight chainsaw, add a stick, and you get a pole saw.
TYPE There are three types of pole saw. You can choose any one of them based on your requirements.
CORDLESS POLE SAW Cordless pole saws are said to be the handiest pole saw as it removes the hassle of carrying wires and cords during pruning. It operates through a rechargeable battery. But, due to its battery pack, its operation time is very specific. If you want to extend the time for heavy duties, you can use extra battery packs.
One of the best advantages of cordless pole saw is its need for low-maintenance. You would hardly need to maintain its well-being.
GAS POWERED POLE SAW Gas powered pole saws are mostly chosen by the professionals for its heavy-duty bars and chains and have the power to cut huge and large branches with ease. This pole saw can be extended up to 9 inches so you might distinguish its expertise in trimming high rise trees. It is good for regular use. It is heavier than the electric one and noisy also. Despite being heavy, you would not face any problem working with it as the pole saw is easy to balance.
ELECTRIC POLE SAW Electric pole saws are preferred for small branches trimming as it has blades of 6"-10". It weighs about 10 pounds that means you can carry the saw effortlessly. It does not require high maintenance as well. Plug the long extension cord before you start, aim at the branches and begin pruning with this electric pole saw.
More details
Guide on How to Pick the Perfect Pole Saw
Apr 16, 2018 | Garden
How big of a Miter saw should i get?
a good 10 incher will handle most DIY jobs .compound slide saw
Mar 02, 2016 | Dewalt DW715 Heavy Duty 12" Single -...
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Mitre saw blows breaker
bad cord, switch wired wrong, or bad motor. Pull the cover off the motor. Disconect the power. Sping the balde by hand and look at the bars on the comm, end of the armature. They should be evenly colored and the spacing between them should be even and clean cut looking. If there is heavy discoloration on one or two bars or heavy pitting between a couple bars the armature is likely bad.
Jan 02, 2014 | Dewalt DW715 Heavy Duty 12" Single -...
Skilsaw 5150 7 1/4'' stopped working, I think it overheated?
Yes, it overheated. Not worth fixing, replace it. What happens is that with a very heavy load the saw tries to run a lot of current through the little coil wires that are only insulated with varnish. They heat up, the varnish melts, and a few of them short out together, which increases the current further, causing more heat and more melting until enough shorting in the coils that it won't do anything except trip a breaker. To avoid this in the future-- always use a heavy-enough extension cord and always use a sharp blade. You need a heavy enough cord so that it can supply full voltage instead of more current. The nick in the cord could have contributed to this.
Feb 13, 2013 | Skilsaw "5150" Circular 7 And 1/4 Inch
Will this saw be able to cut steel on truck and trailer frames? the steel may be 2-3 inches thick in some places. other places only about a half inch thick. is this a good tool for cutting heavy metal?
Never heard of cutting steel with a chain saw. What works best for me has been a sawzall with a good quality steel cutting blade. The real thin metal cutting blade on a circular saw works pretty good also.
Mar 28, 2011 | Husqvarna Garden
My saw keeps cutting out when cutting heavy wood, does that mean my saw is wore out, or what can i do
When it cuts out while cutting heavy wood, there are several things you can do.
First, check to be sure you are not feeding the wood in too fast.
Next, be sure the saw blade is clean of pitch.
And, be sure the blade and fence are aligned.
Are the teeth of the saw showing completely over the wood? Just the tooth should stick up over your board.
Also, if this is a continuous problem despite cleaning and all the above, installing heavier belts sometimes helps.
"woodworker by night"
Handy Andie
Mar 20, 2011 | Craftsman 10" Table Saw
Engine cuts out during heavy rains. This started
I HAD THE SAME PROBLEM BUT WITH AN ASTRO VAN. THE PROBLEM WAS WATER WAS GETTING INTO THE FUEL PUMP CONNECTOR UNDERNEATH THE VAN, NEXT TO THE FUEL TANK.THIS WAS CAUSING A SHORT, NOT BAD ENOUGH TO BLOW THE FUSE, BUT ENOUGH TO CAUSE THE PUMP TO SHUT DOWN. BEST WAY TO DUPLICATE THE PROBLEM IS TO FIND THE CONNECTOR AND SPRAY IT WITH WATER WHILE THE VAN IS RUNNING. ALSO DO A WIGGLE TEST, THIS IS DONE BY GRABBING THE HARNESS TO THE PUMP AND MOVING IT AROUND, IF YOU HAVE A LOOSE CONNECTOR OR A BAD WIRE THE VAN SHOULD SHUT OFF.
Jun 07, 2010 | 2000 Ford Econoline
Dw705 12" mitersaw
I do not know your machine but from previous experience I know that a sircular saw blade wobbles when it was over heated during use.
Oct 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
