Question about ElectroVoice Audio Players & Recorders
I am a dj and i have a set of EV speakers but lately on speaker is giving me problems. It cuts in and out and the bass sound goes thin and the sound distorts. I have checked it with different leads and amp but still giving Problem
  • 604 Answers
It may be an interanl crossover problem, you will have to open the cabinet to check and see if it looks like the coils (on crossovers) have gotten hot, (therey will be discolorationg on the coils)..you can bypass the crossover and power up the speakers (at low power/volume level) to test weather this is the problem or not, but it sure sounds like it. The cross over networks cost about 40 dollars the last time I checked
Posted on Mar 20, 2011
How do I stop vibration sound from the L1??
Try asking your question in the Bose forum (there's a DJ section).
Bose L1 Musicians
Jul 12, 2014 | Bose L1 Speaker
I am a dj and have ev speakers and a mackie2600 amp. Last night on my amp one side was working the other side the bottom light was lit but not moving. No sound from speaker. I wiggled the wire it started...
If not the cable suspect the coil in the speaker cut. Try if the speaker pin mearuring low resistance. If not the speaker failed. Try to open the dust cap. And find out the disconected coil
Oct 24, 2017 | ElectroVoice . Speaker
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
How can i get more bass out of my frontman 65, it sounds good but it has very bright thin sound. i was wondering if an eminence swamp thang speaker would fix that problem.
Changing the speaker MAY turn out disappointing results. There is a limit what you can get from a 12 inch speaker in the bass range. USUALLY the amp manufacturers match the speaker/cabinet/and amp for about the best performance that can be expected. Want more bass? Step up to a 15 inch speaker.
Nov 01, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Whenever a little bass sound - explosions, gunfire, helicopter blades, etc., ''PROTECTOR'' flashes on LED and shuts down receiver. Seems to happen more frequently lately. Subwoofer cable sturdy, no...
The protection feature on these units will shut off the receiver when there is too much power draw or when a speaker wire is touching another wire. First, check all of your speaker connections and make sure the wires are nicely twisted and inserted into the speaker and receiver with no stray wires touching. Secondly, if this doesn't correct the problem, try going into your speaker settings menu on your receiver and select "small" for each speaker. Let your sub handle the bass. The sub cable should have no effect on the protection feature of the receiver. The speaker wires, however, are the most common culprit of a receiver turning off (protector). Hope this helps.
May 03, 2009 | Sony Televison & Video
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
Subwoofer works - sound goes away after some time
POSSIBLY A BREAK IN THE SPEAKER SUPPLY LEADS TO THE ACTUAL BASE UNIT
WE HAD THIS AND IT WAS NOT THE SPEAKER BUT THE BOLT ON CONNECTION UNDER THE SPADE TERMINAL ON THE BACK OF THE BASS UNIT
Dec 16, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Only subwoofer works at high volumes
It could be your receiver but you can try seeing if the Woofer has a input knob at the back, maybe this down, or maybe.if possible turn down the amount going to the woofer with your receiver.
Dec 27, 2007 | Kicker 02S10L74 Car Subwoofer
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
