Question about Fisher and Paykel GWL11 Top Load Washer
Fisher paykel Washer error code 3 or 7... Ecosmart
  • Anonymous Aug 14, 2008
    Today my GWL11 made a strange noise but went through the cycles fine.  The next load was a different story.  It wouldn't completely drain or spin.  When I lifted the lid I smelled something electrical burning.  I turned it off.  We've tried unplugging and restarting but nothing works.  It appears that the water pump is dead as well.  It's only two years old.
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
  • 30 Answers
You have a burnt out pump.cheers
Posted on Aug 27, 2008
5 Suggested Answers
reizac926
  • 56 Answers
SOURCE: I have a fisher & paykel ecosmart washer no water
Please make sure that your water supply lines are properly connected and turned on. Also, there are typically small filters at the end of the hoses where they connect to the washer. Check those and clean them if necessary. Since the hoses will be disconnected at that time, flush the lines by running the water into a nearby drain or bucket.
Hope this helps! Rate my solution!
Posted on Jan 05, 2010
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
  • 713 Answers
SOURCE: i have a #37 code (pump blocked error) on my
Hi just read your posting.Now 1st I need to know which type of pump you have on your machine,Please look underneath the machine for me to the front right.You should see a red or black fan.This is your pump.If you do not have a red or black fan attached to your pump then you have the other type with is held in by 2 screws.Please reply and tell me which pump you have and I can guide you throe the removal and cleaning of the pump.Also is your machine draining into the laundry sink or elsewhere?
Posted on Jun 27, 2010
SOURCE: Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Posted on Dec 08, 2010
Fisher and paykel ecosmart 96193-a wont drain
Fisher and Paykel might be able to supply a repair manual.
May 20, 2014 | Fisher Paykel EcoSmart GWL15
My ecosmart washer doesnt spin, and after about 30 seconds it beeps
Can you tell me what lights are on when it is beeping
so i can work out what fault code it's displaying.
Aug 26, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel gwl15 wont completely drain
Also check the clear pressure tube for blockages,
Blow air down the pressure tube to remove any blockages
that would prevent water level from changing.
Jan 02, 2012 | Fisher Paykel EcoSmart GWL15
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
THE WINGS ON THE AGITATOR ON MY FISHER PAYKEL ECOSMART TOP LOAD WASHER ARE BREAKING OFF. CAN I REPLACE THIS EASILY?
yes loosen the wing nut nd remove nd replace , u can order part from F&P direct 1800650590 ask for spares
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
After washing my fisher paykel toploading washer will not empty out
possible a blocked pump , it shud beep , come up with a code read the 8 lights on the top
Jan 25, 2010 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
The washer wont drain
Check clear filter //pump
Sep 29, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
633 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
