Question about Honeywell Programmable Thermostat Heater
Where is the common on rth 6350/6450 series, have extra red wire hvac says it needs to plug into a common
    President:
  • 1,654 Answers
The common is the ground. This can be hooked to the green wire from electric supply or grounded to the cabinet in the unit if the unit is grounded.
Posted on Mar 20, 2011
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
I installed the RTH 230B thermostat, Theheat only works when set to the cool mode, I only have gas furnace(no ac unit). My old wires are Red, white, green and blue. What wires go where?
Hey jim Try....RH/RC jumper (connected with a small piece of wire)...RH/RC=RED...W=WHITE...G=GREEN blue=unused... should give heat only (in heat mode) no ac..tks
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I am trying to replace a Honeywell thermostat model #T87F with a model RTH 111, which Honeywell advises is compatible. After following all instructions, I have cooling, but no heat. This is a one zone...
Hi, Have you jumpered Rc and Rh??? I bet you just have the red wire under the Rc terminal only...heat goes on when power goes from Rh to W... the white wire should be on W and energized (24v) when the t-stat is calling for heat...
Here is a list of each common terminal and what their commonly used for. Alsolisted is what colors are commonly used. NEVER ASSUME these are what youhave. Verify all your wires by following each to each piece of equipment. Thiswill help you to be able to match your equipment with the terminal.
Here is the rest of the tip that I wrote...
Thermostat Wiring and Terminal Designations
heatman101
Aug 23, 2011 | Honeywell Heating & Cooling
Honeywell RTH 7500d is not working.
If nothing is happening then I am wondering about tje power... If you have access to a digital meter, you should have 24v a/c across the R wire and the C wire...
Did you make sure to turn off the power at the air handler or furnace before unhooking the wires at the t-stat??? If not then you have blow a fuse in the control board or burnt out the transformer...
If you have power on R then jumper to G and the fan shoudl come on... if it does then the t-stat is bad...
This should give you a few things to try and is what I would be doing if it were my service call...
heatman101
Apr 29, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Have two wires disconnected from a carrier hvac unit that goes to supply air fan. they are 4 wires total. one yellow goes to l2 on circuit board and red to bm, the black and blue wire is not connected...
Hi, these wires control the speed of the blower motor.L-2 is one power leg and red to bm (blower motor). If the other 2 wires are wire tied out of the way, and they have always been this way, that's the way they come from the factory, to control different speeds. On a 230 volt blower motor, you will see a yellow which normally goes to L-2 on the board. Then you will have a black, red, and sometimes blue. Sometimes you will see L-2 with yellow, L-1 could be any one of the other colors as they are marked on the motor. Low, Med, and High speed are what these extra wires are for. So, you are only using 1-speed. If it is running, and has been, forget the other 2 wires. If its not working, look for a L-1 on the board and connect any one of the other 2 wires. Like I said though, if this is always how its been and running fine, this is a normal termination. Let me know if you have a motor problem, and I can walk you through it.
Shastalaker7
PS The BM red wire is L-1 on the board.
Dec 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
How to hook up Honeywell rth 7600. have an extra wire
From what I'm seeing the 7600 is not compatible with a heat pump. Where are you landing the orange wire?
May 12, 2017 | Honeywell Heating & Cooling
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
234 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
