Question about GE Refrigerators
The Freezer portion keeps on developing frost on the back and does not freeze unless I take everything out, turn the freezer off, and dry everything out. Then turn the freezer back on.
  • 42 Answers
G.E. refrigerators use a glass tube heating elemnt for the defrost system. They are the most common thing to go out on the G.E. defrosting systems. The most common of the elements part # is WR51X10101
Posted on Mar 20, 2011
  • bealls_2001 Mar 20, 2011
    Makes sense... Thanks so much. I will get the part on Monday.
  • RaneyAPPL Mar 20, 2011
    that part number is for the sde by side ref. you might need the model number to find the one for yours. WR51X10101 is the most common, but might not be the one yours calls for. when you by the part give them your model nuber and have them look it up.
How to defrost
If this is an automatic defrost or "no-frost" freezer and it has developed a lot of frost and ice, call a repairman. That should never happen.
But if it's a manual defrost model, follow this procedure.
1. Turn off the freezer. Then remove all the food and toss it into a picnic cooler to keep it frozen. (Some blue ice packs will help.)
2. Open the drain on the bottom of the freezer, and put the end of the hose from the drain (which most have) into a roasting pan to catch the water from the melted frost.
3. Leave the door open. If you have a small electric space heater, blow warm air into the freezer to speed up the melting process.
4. Don't scrape the ice -- you could puncture a cooling coil in some units, making the freezer useless.
5. In about 30 or 40 minutes (15 with the space heater) the ice will be melted.
6. Dry the interior with a towel, toss the food back in, turn the freezer on again, and you're done.
Jun 02, 2015 | Frost Freezers
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | GE Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Frost Developing in Freezer. Refrigerator not
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Continously running without stopping
Needs a new thermostat. Get engineer to fit for you. Cheers, Derek.
May 19, 2009 | Jenn-Air JCD2389G Side by Side...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
