Question about Husqvarna Garden
Engine dies when throttle is applied - Husqvarna Garden
  • Husqvarna Master
  • 2,239 Answers
It is running too lean, replace the fuel filter in the fuel tank, check the condition of the fuel hose up to the carb, if it has normak adjuster screws, increase both H and L screw by 1/4 turn and see if this improves it, if needed increase the H screw by a further 1/4 turn.
Posted on Mar 21, 2011
V star quits when throttle is applied carbs redone and cleaned. I give up!!!!!!
how about the plugs or fuel line itself could be a bad fuel pump wihich are in the tank ck the fuel pressure
Jan 20, 2015 | 1998 Yamaha V Star Classic
Engine dies when throttle applied
Hi, Tim the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. The gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/49-v-star/68346-650-starts-but-dies-throttle.html
https://yamahaclub.com/forums/topic/15251-idles-fine-but-dies-upon-throttle
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 12, 2013 | 2007 Yamaha V Star 1100 Classic
02 shadow 1100 starts up but dies when throttle applied helpplease
When was the last time you cleaned the carb,and has it been setting up for a period of time
Apr 18, 2013 | 2002 Honda VT 1100 C Shadow Spirit
Engine dies when choke is taken off or when throttle is applied.
where the valves set cold or hot? could make the world of a difference...is there intake leaks? bad floats perhaps....its a problem that will take some time cancelling out problem by problem
Oct 09, 2009 | 2008 kawasaki Ninja 250R
Trimmer dies when you apply throttle
Sounds like it might be getting to much gas. What position is the choke in during all of this? If you're giving it throttle it may be flooding itself out.
Aug 26, 2009 | Garden
Engine will idle but when throtle is applid it dies
Check fuel pressure & TPS. (Throttle Position Sensor)
Jun 04, 2009 | 1999 Dodge Grand Caravan
1996 GMC K2500, 5.7 eng, auto trans. Sometimes when you let off the throttle and apply the brake the engine will die or try to die. I had the a/c serviced and while idleing the engine suddenly stopped,...
You need to clean the idle speed control valve and the throttle valve, they are most likely sludged up, use carb spray, do it with the enginge at high idle speed, after you are done disconnect the batt. for 5 min. and the reconnect, drive a few miles and your problem should go away.
Sep 04, 2008 | GMC K2500 Cars & Trucks
Garden Logo
42 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
