Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Suction seems very fierce, so strong i have trouble pushing the hoover! I have cleaned the filter but It was not like this before
    Sergeant:
  • 192 Answers
It may be something as simple as a string wrapped around the wheels.
You might also check to see if it needs a height adjustment.
Posted on Mar 20, 2011
Dyson ball dc25 filter B keeps popping out
Hoover or dyson , can not be both
Jul 22, 2016 | Dyson DC25 Vacuum
Red power light blinks even with completely clean canister and filter
Check for a filter where the air blows out of the machine. Could be clogged.
Jul 26, 2013 | Hoover S3755 WindTunnel Bagless Canister...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover windtinnel suction problem
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
Apr 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Dyson DC07
This is an incomplete solution. Mine (DC 14 Animal) worked great and then it didn"t and then it did after checking to make sure that all the parts were on securely. I noticed that while the suction sort of seemed normal, it was not strong enough to pick op fine dust from window sills.
The elbow thing near the floor on the right side was not seated properly. I fixed that and it worked great for a while and then lost too much of suction again for no apparent reason. I took a look on the Dyson web sight and they have a trouble shooting guide. The first step is to inspect the main filter and clean it. If I do this again I'll go through the rest of the check process before I clean the filter with cold water as recommended to avoid waiting (12 hours?) for the filter to dry. Mine did not appear dirty and I was unable to rinse out scads of dirt.
I followed the instructions for clearing airways and checking seals... with the canister removed, all suction seems to be fabulous. I'll know in the morning if it really works again after the filter is dry and I can reassemble the thing.
Short version? Try the troubleshooting guide at Dyson.com. I'll try to add to this if it works like new again! All in all, it seems simpler to maintain and trouble shoot that any other vac I have owned.
Good luck,
Tim
Jan 08, 2008 | Vacuums
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
79 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
