Question about KitchenAid KESC308LSS Electric Kitchen Range
I have a KitchenAid KESC308LSSO Electric Range. It's around 6 years old. Today, the electronic control/display panel went out. No LED's light; however, when any buttons are pressed on the panel, it responds with a beep -- which lets me know that it recognizes that buttons are being pressed. Also, when I press the Oven Light button, the oven light does, in fact, toggle on and off in response to the control panel. Also, the mechanical (rotary) knobs that control the cooktop burners are working -- i.e., the burners turn on and heat up correctly in response to the control knobs. The problem is that the LED display info is all dark; so there's no way to set or control the oven. Has anyone seen a problem like this before with a KitchenAid Range? Any idea what went wrong, or how to fix this?
aborcass
  • 2651 Answers
SOURCE: My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Posted on Nov 30, 2008
ginko
  • 19396 Answers
SOURCE: Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Posted on Dec 14, 2008
Treefrog15
  • 127 Answers
SOURCE: Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
SOURCE: oven heat wont work, light won't turn off, door won't lock
I have the same issue
Posted on Jul 31, 2009
pappapumpdaf
  • 635 Answers
SOURCE: Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Posted on Mar 05, 2010
The display/control panel on my kitchenaid oven model KESC308LSSO is functional but does not light up. What part would I need to fix this? + looking for video of repair
I assume the display is hard to see but otherwise the unit function correctly? I'm going to gear my answer to this issue. If everything on unit functions but just can't see clock and temp. settings, you have a bad display. That's gonna be part #2. I'm not how to upload video but go to youtube and type in Kitchenaid slide in electric control replacement. The top video should give you a good idea on how to change display board out. Good Luck
Sep 18, 2017 | KitchenAid Microwave Ovens
F2 E1 error shows on display. KitchenAid model KESC308LSSO Electric range. Oven stops working after 90 minutes at 350 Def. F. Starts working again after cool down.
On your model the "F2E1" error is for a faulty control board and it will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 24, 2012 | Kitchen Ranges
Display panel stopped working
Nov 9, 2009 ... I could thump it with my fist, not hard, just a light thump, and it would come back on ... Problem with KitchenAid KESC307 Electric Kitchen Range ... the ribbon cables and the panel can be removed to a convenient work surface. www.fixya.com/support/t3391463-kitchenaid_range_kesc307hbt8_display www.fixya.com/support/t3391463-kitchenaid_range_kesc307hbt8_display
Just checked this site and it has an answer to your problem. Very complicated, but I am sure you will be able to follow it
Feb 15, 2012 | KitchenAid KESC307 Electric Kitchen Range
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
LED display not working
Did somebody use the control lock by accident. Here is how to disable it. Hopefully it will work: The Control Lock feature shuts down the control panel pads to avoid unintended use of the oven. The Control Lock feature may be used either when the range is in use or turned off (for example, during cleaning). To lock/unlock control: Before locking, make sure the oven, the timer, and Timed Cooking are off. Press and hold the START pad for 5 seconds until ?CONTROL LOCK? appears on the display. Repeat to unlock, and ?CONTROL LOCK? will disappear from the display. Hope this helps Jason
Sep 04, 2007 | KitchenAid KESC308LSS Electric Kitchen...
Oven is not working
Both elements are controlled by a common relay on the ERC (Electronic Control Card) and cannot be repaired. The ERC needs replaced. This is also referred to as the Clock/Display.
Aug 17, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KESC308LSS Electric Kitchen Range Logo
375 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
