Question about HP LaserJet 1320n Printer
Hi, I'm not able to print on my hp 1320 printer. When I go to the print option I notice a word "paused" under the printer icon. I opened each tap on the properties and there is nothing that determines paused. Can you please help?
  • 22 Answers
Go to printers, right-click your HP 1320 and choose "Continue".
The printer should change the status to ready after printing the remaining print job in memory.
Hope i was of any help. If so, please rate me.
Thank you.
Pcsimples
Posted on Mar 20, 2011
Printing on both sides
Make sure the Automatic Duplexing option is enabled:
Enter Control Panel then Devices and Printers.
Right click the printer icon, then Printer Properties.
Click the Device Settings tab.
Set the Automatic Two-Sided Duplex Accessory as installed and click OK to save.
Now Automatic Duplexing should become available.
My LaserJet 1320 will no longer do duplex printing with Windows 8
Aug 07, 2014 | HP LaserJet 1320 Printer
Hi I have a HP LaserJet 1320 Printer and when sending multiple documents it is pausing between them. I have to press the Green button to make them print, until the start of a new document when I have to...
Is the paper size set on the computer for the size of paper you are printing to?
Usually if you have to give a 'thumbs up' to the printer is because it is trying to print on an different size paper.
Aug 09, 2011 | HP LaserJet 1320 Printer
Hi I hv installed hp laser jet 1320 printer in my system but print on both side option is not shown in printer property
Do you have the 1320D or just a 1320. Only the D version will duplex automatically. The base version requires you to manually duplex. If you are sure you have the duplex version, then check the settings in the print driver and make sure it shows that the duplex option is installed. The driver often defaults to no duplexer.
Jul 05, 2011 | HP LaserJet 1320 Printer
I have a HP J6400 all in one printer. Successfully hooked up to wireless router. When I print from computer, I get error message. Does not print
The Printer must be offline.
Make sure you have selected the correct icon under your printers as he default printer.
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
I hope this helps.
Feb 04, 2011 | Office Equipment & Supplies
Can't install hp 1320 printer
Hi downward_man,
Here's the instruction on how you will install your HP Laser Jet 1320 Printer:
1. Access the HP hardware support site to retrieve the HP LaserJet 1320 driver download.
2. Click the link that represents your computer's operating system.
3. Scroll down the page, and click the "Download" action, below the "Driver - Universal Print Driver" table. Opt to save the driver, as the download file has the setup application that is needed to install it.
4. Double-click the setup application's icon from its new file location on your hard drive. The HP installation application will open automatically.
5. Click "Next" to proceed to the first installation steps.
6.Select all of the HP recommended installation options, and click "Next" to begin copying the driver's files and components to the computer.
7. When the HP installation wizard asks, plug the HP LaserJet 1320 USB sync cable to the USB port, located on the back of the printer hardware. Connect the other end of the cable to an open USB port on your computer.
8. Click "Finish" to complete and conclude the HP LaserJet 1320 series driver installation process.
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | HP Laser Jet 1320 Printer
HP photosmart printer is offline- how to correct
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
Try printing again. I hope this helped.
Jan 02, 2011 | HP Photosmart D7260 Printer
My printer is "offline". kathrynmcclellan@att.net
Dec 16, 2010 | HP Officejet 4315v All-In-One InkJet...
Hello,my hp laser jet 1320 does not work correctly,I work under an office network, some time it prints and some time does not print specially about pdf files or high size files, the alert is: fail to...
Is there a typical application you are using? I noticed that file size (especially in adobe) can be an issue. If you go to printer settings (start / settings / printers / right click on the 1320 and select properties) choose device settings and the very bottom item is printer memory. I would increase this to like 80mb.... hope this helps
Jul 19, 2009 | HP LaserJet 1320 Printer
NUMBER OF COPIES
If you cannot print more than 1 copy, click on...
Start -> Control Panel -> Printers -> Right click on HP 1320 printer icon -> Properties -> Device settings -> Disable mopier mode (last option)
This worked for an HP 1300, 1320 and as well as an HP P2015d using the HP 1320 driver.
Apr 11, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
