Question about Ebel Classic Wave 9090F249725 Wrist Watch
The stem seems stuck and I can't change the time on my watch. I can't remember having this problem before. Shouldn't it pull out easily so I can manually change the time? Thanks
    Problem Solver:
  • 5 Answers
Hello some watches have a screw down crown turn the stem screw counter clockwise a few turns and then try pulling out gently. hope that helps
Posted on Aug 24, 2011
I just tried this on Dad's watch, and it worked!
Posted on Nov 06, 2011
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Mar 25, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Luminox Titanium Watch
you set it using the wheel pull it out , it should have two positions, one adjust time the other one date and chronograph, I see if I find full manual.
Aug 03, 2008 | Navy Seal Luminox Watch
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Jul 22, 2010 | Bulova Watch
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Problems with setting the date on this watch
mcdevito75 here, It does seem to be a hard way to set the date. I would imagine to you have stem and not buttons, Try this slip your fingernail just under the stem (winder) and lift the stem to it"s first position, now turn the stem either toward or away from you to change the date easily.
Jun 21, 2010 | Jaeger-lecoultre Master Compressor Memovox...
I can't seem to find the proper way to change the day and day of the week for the watch without manually spinning for a long time. today's Date: Sunday 25 but the Watch's Date: Monday 29
mcdevito 75 here, Most likely there are 2 positions in the stem (crown assembly) pull the stem out very carefully to it"s first position this should allow you to change the DATE either turning the crown toward you or away from you, once you get to the proper DATE, pull the stem out to it:s 2nd position, spin the hands until you get the proper day. Regards, Mike D 75
May 21, 2010 | Kenneth Cole KC1289 Watch for Men
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
Apr 14, 2009 | Seiko SGF204 Wrist Watch
Changing the DAY on this analog watch.
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 | Watches
Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Jan 05, 2008 | Watches
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Dec 03, 2007 | Watches
Ebel Classic Wave 9090F249725 Wrist Watch Logo
476 people viewed this question
Top Ebel Watches Experts
Ansel Alberto
Ansel Alberto
Tom Chichester
Are you an Ebel Watch Expert? Answer questions, earn points and help others
